0 members (), 108 guests, and 0 robots.
Topics128,115
Posts1,056,292
Members48,439
#1408202 05/01/2021 8:09 PM
Got new hoses for my truck and noticed that they are 1/8" ID versus the old ones that are 3/16" ID. Any cause for alarm? Thanks
Ed
Sir Searchalot
Sir Searchalot
Are you talking about rubber hoses from frame to front wheel cylinder and rear frame to axle Tee?
If they are sold by a reputable vendor they are OK. I've not seen brake lines less than
3/16. Those are metal. I assume you are measuring the hole in the fitting that is swaged to hose? Don't think you can get an accurate measurement there unless you use a drill bit as a gauge.
Bottom line, I wouldn't worry about it, the pressure will be there.
Forty9 #1408227 05/01/2021 10:51 PM
These are the rubber hoses. The hose itself is marked 1/8" ID. These are Raybestos hoses, fittings are same as 3/16" ID hose. Thanks for input, probably over thinking it!
Ed
Forty9 #1408230 05/01/2021 11:33 PM
Sir Searchalot
Sir Searchalot
I see now where you got the 1/8. Legit rubber brake hose ID is 1/8, 3/16, 1/4
3/16 steel brake line is the O.D.
The ID is basically 1/8, the line having a wall thickness of .028-.035, depending on material and manufacturer.
