6 members (TUTS 59, Ponchogl, Steelonsteel, Gdads51, Gray_Ghost, ESum), 92 guests, and 4 robots.
Topics128,088
Posts1,056,125
Members48,435
#1407875 04/29/2021 2:57 AM
Howdy, my 55 1st series had been sitting for a couple of years.
When I got her running again I noticed a leak coming from the
timing cover/engine mount area. I snapped a picture that I
took from the passenger side fender. Any advice or suggestion
is greatly appreciated!
Crankshaft front seal - it dries/sets-up in-place, and then leaks in place after the crankshaft is rotated?
Im not sure, I just noticed it when I started running it. Going to try and remove radiator, timing chain cover. Is this something a speedy sleeve would
fix?
Well if there is a grove where the seal rides, then a sleeve would probly be a good idea. Might just be a hard seal? You'll see when its opened up. Oh, and the timing chain cover does NOT need to be removed to replace the seal.
AD Addict & Tinkerer
This is a somewhat tedious job, not meant for the “Faint of Heart”, but with guidance, doable by most that possess a bit of mechanical aptitude.
You’ll need to pull the harmonic balancer to replace the seal. The balancer has threaded holes to bolt a puller to. You can rent one from most FLAPS. Don’t use a three jaw puller as it may damage the rubber or rivets in the harmonic balancer.
Once the balancer is removed you have access to the seal. A bit tricky, but you can get the old seal out, without pulling the timing cover. Don’t attempt to pull the cover, as access to the two lower bolts are from inside the crankcase. I used a small three jaw puller with the jaws inverted. I’m sure there are other methods, that other on this forum would love to share.
Once removed, inspect the area on the harmonic balancer for wear. If worn, you can buy a stainless steel sleeve to go over the worn area to give your new seal a nice area to ride on. Mine needed the speedy sleeve so I provided a picture of what it looks like installed.
Assembly is a bit more tricky but certainly doable! To tap the new seal in place, I use a large socket that contacts the outside edge of the seal and has clearance inside for the crank shaft. A little smear of #2 Permatex or suitable Locktite on the OD of the seal helps.
Next is to replace the balancer. A subject of debate as to how to do it, has been raging for years on this forum. I installed this balancer by hammering it on the same way the GM factory trained mechanics did it for years. You will need to drive hardwood wedges between the flywheel and the back of the bell housing, to protect the thrust bearing on the crank. You’ll also need to use something like a block of wood (on the end grain), to protect the balancer from hammer marks. My balancer has the ears for a hand crank, so I fabricated a installation tool from a few black iron fitting, so I had clearance for the ears.
Others have threaded the snout on the crank shaft, so you can use a balancer installation tool, definitely a much gentler method with the added security of a bolted on balancer.
Good Luck!
Phil
Project Journals
Stovebolt Gallery Forum
Thank you for the detailed explanation! And photos! I really appreciate it. I’ll start digging into it this weekend. I’ll keep you posted!
thumbs_up
Phil
Project Journals
I use a Lisle 58340 Seal Remover for this type work.
Lisle Seal Remover
The other trick is to cut a piece of plastic from a pop (or soda if you live in certain geographic regions) bottle. Wrap it around the OD (the sealing surface on the nose) of the crank and slide it back under the lip of the old seal. Then slide the tip of the tool under the lip and over the top of the plastic.
The thin layer of plastic protects the sealing surface of the crank.
Rusty
The poor man's trick to removing a seal like that is to screw a sheet metal screw into the metal rim of the seal and use a pry bar under the head of the screw to pop it out.
I have successfully used the screw into the metal approach. I have also seen people ruin a good sealing surface when the drill bit jumped.
Rusty
That is a good point, but wouldn't be an issue with a timing cover seal as the sealing surface is laying on the workbench (on the balancer). A light tap with a center punch helps keep the drill in position.
With such a small bit, I would be concerned about the bit going in too far, having it catch on something inside and snapping off because you know that once you break thru, that drill is going to want to go in full depth. I would use a drill stop or a piece of tape limiting the depth, to help prevent such a disaster from happening.
Phil
Project Journals
Good point Kevin. I work on too many different cars. I forgot that the sealing surface was the OD of the hub on the backside of the balancer.
Thanks for catching my mistake.
Rusty
Ok, I had a chance to remove the radiator and the grill.
I’ve got a puller and will try to remove the harmonic balancer soon.
Ideally I’d like to try to leave the timing cover on.I ordered a speedy sleeve and front seal from Rock Auto.
Thanks again for all the hints and tricks!
Hey guys, getting ready to reinstall should I put ib weld in the grooves on the damper shaft? Thanks, I am using a Speedy Sleeve,
If I remember correctly, the speedy sleeve should have come with a compound you use to attach the sleeve and that is all you should need to use.
58' 3200 235 3-speed/OD
With the depth of those grooves, I would fill them with JB Weld first, then use a non-hardening sealer as specified in the instructions. I used some type of Loctite, but can’t remember which one.
Phil
Project Journals
