| | | Forums66 Topics128,032 Posts1,055,438 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2005 Posts: 35 Junior Member | | Junior Member Joined: Feb 2005 Posts: 35 | I was trying to find out what my truck actually is,it´s supposed to be a ´51 6400. engine prefix is HAM,wich would be a ´50 216, and the tag on the drivers side door post just says NS 23,nothing more,any ideas?
car nut for life!
| | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Do you know where the truck was built?
The number schemes seem to vary from country to country...
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Feb 2005 Posts: 35 Junior Member | | Junior Member Joined: Feb 2005 Posts: 35 | all I know is that is was sold new to the swedish army,and that the bed was put on after it came to sweden,
car nut for life!
| | | | | Joined: Feb 2005 Posts: 35 Junior Member | | Junior Member Joined: Feb 2005 Posts: 35 | got it now,finally got a hold off the right archives,I´m getting a copy of the original registration papers in a couple of days,I found the original number plate.
car nut for life!
| | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Got the answer, or just have the truck?
What numbers are on that original plate, and does it say where the truck was built?
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Feb 2005 Posts: 35 Junior Member | | Junior Member Joined: Feb 2005 Posts: 35 | ok,I was a little unclear:I got the truck home a week ago,I got a hold of the original Licence plate,that´s what I ment,I checked the plate on the door post again today,it just says serial no:NS 23,thats it,whith the original licence plate number,I can order the a copy of the last registration papers that the truck had,so when those arrive,I know for sure what it is,I need those anyway to get it back on the road legally here,I´m going to try brake the engine free tommorrow,it´s been sitting for a while whith diesel in the cylindres,but I´m not very hopefull,last time the truck ran was in ´67!
car nut for life!
| | | | | Joined: Mar 2005 Posts: 59 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 59 | dont let your hopes down my 42 sat outside since 66 and ran in about 2hrs work | | | | | Joined: Feb 2005 Posts: 35 Junior Member | | Junior Member Joined: Feb 2005 Posts: 35 | I´m hoping it´ll run whithout taking the engine apart,then it might be ready for a test spin next week,if I get som wheels on it.
car nut for life!
| | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | NS 23 doesn't add up to anything for me.
The engine prefix does seem to be a '50 216, but from a sedan delivery, not a medium duty truck.
When you have more information post it and I'll see if I can do anything with it.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Feb 2005 Posts: 35 Junior Member | | Junior Member Joined: Feb 2005 Posts: 35 | well,the doors have vent windows,so that would be 51-53,is there any number on the trans that could tell the year of production?if I could prove that it was made before 51-01-01,it would get the 50 model when I put it back in traffic,and a 50 or older vehicle here,is inspected every 3 yrs,a vehicle 30yrs or older is inspected every 2 yrs,so it would save som time and money.
car nut for life!
| | | | | Joined: Feb 2005 Posts: 35 Junior Member | | Junior Member Joined: Feb 2005 Posts: 35 | engine unstuck today,turns freely,there´s one exhaust valve thats a little unhappy yet,but I´ve drowned it in lube,so tomorrow I was hoping i would get it started,I´m going to take the oil pan down first,and clean the oil-scoopers on the rods,just in case.
car nut for life!
| | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Both the trans and axle should have numbers on them. I don't recall if those numbers indicate when the units were built. If I remember long enough I'll look when I get home tonight.
Assuming those units have not been replaced a date code would only tell you the truck was made no earlier than that date.
Could your 1950 motor be what you need to call it a '50 or earlier?
I've seen people update the doors just to get wing windows. It could have been done to this truck too.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | My source says that year is part of the code on rears and transmissions. It does not cover big trucks, so I may not be able to identify the year on the rear, but I think it will work on the transmission.
Send me the number once you have it, and I'll take a look.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Feb 2005 Posts: 35 Junior Member | | Junior Member Joined: Feb 2005 Posts: 35 | got copys of the original registration papers,it´s a ´51 6403,papers said it was last registered 12/70,been sitting ever since.
car nut for life!
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Well I'm glad that part is cleared up but I'd still be interested in what assembly line it came down. Is it left hand drive? | | | | | Joined: Feb 2005 Posts: 35 Junior Member | | Junior Member Joined: Feb 2005 Posts: 35 | yep,left hand drive it is,and the chassis number on the paper also says NS 23,wheelbase is 161" ac. to the old papers,gvw is some 16000 lbs if that helps.
car nut for life!
| | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | Could this be an old NATO Army truck? Maybe that's why the s/n is different... 16000# GVW is correct for the 6000 Series trucks.  | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | A 51 is usually the easiest to identify since it is the only year with vent windows and a pull down to open outside door handle. Through 50 no vent and 52 up pushbutton handles.
Evan
| | | | | Joined: Feb 2005 Posts: 35 Junior Member | | Junior Member Joined: Feb 2005 Posts: 35 | well,the swedish army got it inspected on 30-06-51,and registered it 09-07-51,sold to a private person 05-08-60,then sold again 08-09-60,to it´s last registered owner,last time it was registered was 30-09-70,whorthless knowing,but interesting story anyway ;o)
car nut for life!
| | | | | Joined: May 2005 Posts: 6 Junior Member | | Junior Member Joined: May 2005 Posts: 6 | I know what you are going through with your rig. Here in the U.S. when the goverment sells to the private sector the title states the year that the rig was sold. I have an old M38 willys that the title says it is a 48 but through much research I found out it is a 43. now I get the right parts that I need. I found that ebay is a good place to find the old military manuals, that give all the numbers that were used back then. Good luck. | | |
