2 members (IHPWR, Shof),
116
Mod | | | Forums66 Topics128,034 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2003 Posts: 23 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2003 Posts: 23 | Okay you guys, I've been seeing lately that GMC trucks were a bit different in their numbering. I have been asuming that my 56 GMC 450 was a 1 1/2 ton truck. Is the beast bigger than I thought? I am thinking of turning it into a roll back car hauler once I get my Firebird's new engine in.
| | | | | Joined: Jan 2004 Posts: 12 Junior Member | | Junior Member Joined: Jan 2004 Posts: 12 | I believe it is much bigger than you thought. I have an AC 503 and it is a 3 1/2 ton. It is proably a 2 or 2 1/2 ton. | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | The 450/450-8 with it's 23,000 GVW would be the same as my 2-1/2 ton rated Chevy's. Mike  | | | | | Joined: Sep 2003 Posts: 23 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2003 Posts: 23 | pretty good buy for $800. I think i'll keep on my plans. This ought to be fun.
| | | | | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | 350 series is a 2-ton. 450 is probably a 3-ton. Check the link in my signature for everything you could want to know about GMCs... | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | If i'm not mistaken, The '55 2nd series, & up 350, is indeed a 2 ton, then you have the 370 series(19500lb. gvw), which I think is considered a 2 1/2 ton, then comes the 450 series,(22000lb. gvw) which would be a 3 ton. I'm not as sharp, on these late model GMC's, as I am on the earlier '47-'55 1st series Advance Design(New Design) Trucks. I know with them, a 350= 2 ton, 400= 2 1/2 ton, 450= 3 ton, & 470= 3 1/2 ton. | | |
