1 members (Forty9), 66 guests, and 1 robot.
Topics128,055
Posts1,055,782
We'll here I go again thinking my 235' is just running so good when all of a sudden, my vacuum advance just is not operating. I'm holding around 17 hg's from the line off the carb., but from idle up to about 2500 rpm's the lever is not moving what so ever, the engine want's to stumble a bit to.Could this just be a bad unit or is there something internally wrong in the distributer? :confused:
Can you turn the distributor easily by hand? The vacuum advance gets rusty and stiff over time...
Jim
Jim
Red dot, center of chest ...
I believe you can disconnect the lever arm from the vacuum advance and operate it by hand. By doing that, you could test whether or not the mechanical parts of the advance are operating as expected.
You can also disconnect the vacuum hose from the advance, attach a rubber hose to it, suck through it and see if it holds a vacuum. (Or use a vacuum tester if you happen to have one handy.)
Paul Schmehl CI 6
geek@stovebolt.com
Stovebolt Staff: Geek
Before I suck on a modulator, I gently blow into it first. That checks the diaphragm, and avoids sucking dirt into my mouth.
Fred
52 3600
69 C-10
