| | | Forums66 Topics128,081 Posts1,055,955 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2021 Posts: 52 'Bolter | | 'Bolter Joined: Mar 2021 Posts: 52 | When reassembling is there a kit for replacing the nuts and bolts are do you guys just pick them up at hardware store? Just curious, I am a long way from reassembling. Thanks | | | | | Joined: May 2015 Posts: 11,052 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,052 | The usual vendors sell various kits, such a cab mounting, bed mounting, etc. But I don't know of a full set of nuts and bolts available.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Mar 2021 Posts: 52 'Bolter | | 'Bolter Joined: Mar 2021 Posts: 52 | | | | | | Joined: Feb 2016 Posts: 1,987 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 1,987 | I don't think you'll find a complete kit, now I can tell you from experience if you were shopping for Corvette stuff you can buy EVERY fastener to meet factory specs right down to the markings on the head of the bolts. Maybe someday they will think our trucks are as important.
