| | | Forums66 Topics128,157 Posts1,056,875 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2008 Posts: 70 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 70 | I am wanting to remove the old torque tube and install a newer rear axel I have a 5 speed out of an s-10 to go in it but im having a hard time with finding a rear axel to go under, heres why I want the rear axel to be 6 lug, so i thought a chevy luv its to narrow, a nissan its to narrow, a full size chevy WAY TO WIDE , does anyone know of a newer rear axel that would work ? i know the S-10 axel is where everyones going but I just like the 6 lug look. Thank you all for the help in advance
frankenstein Fabrications
| | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | Your width on your 49 is 60" and has a 4.11 ratio. A 55 to 59 has an open driveshaft, six lug wheel bolt pattern, a 3.90 ratio, and is 61" wide or 1/2" on each side---not a problem for either tire or the overdrive transmission.
Evan
| | | | | Joined: Mar 2010 Posts: 10,299 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,299 | I have a 2001 Nissan Xterra six lug axle on my "50. It is the correct width, 6 lug Chevy bolt pattern, and Limited slip. The only issue is the ratio at 4.64, but my T-5 overdrive transmission works very nicely with it. Later Xterra have ratios in the low "3's" but come with disc brakes.
| | | | | Joined: Mar 2008 Posts: 70 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 70 | 52carl are you running your stock what is it 232 ? im pretty sure thats what i have in mine im kind of afraid when i put the 5 speed behind it its not going to cruse i mean im not wanting to go 90 down the interstate but i was thinking 3.25s ?? or 3.55s ?? rear diffs if i can find them probably only going to find 3.90sin the 55 series tho
| | | | | Joined: Mar 2008 Posts: 70 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 70 | coilover now i feel foolish i never even thought about the 55-59 chevy trucks lol thank you for reminding me
