| | | Forums66 Topics128,101 Posts1,056,180 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2003 Posts: 265 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 265 | I am trying to find a rear brake drum for my 1950 GMC 353-24 2 ton truck. Does anyone know of a supplier? No one locally seems to be able to help. Also, is my cab the same as the smaller trucks? I emailed American Classic today and they didn't know if the rubber parts would fit my cab. | | | | | Joined: Feb 2000 Posts: 587 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 587 | Cab stuff all the same, cept maybe the floor cover over the trans and vac fittings for brakes coming in firewall area. You may also have a dash switch for brakes if a "tractor" truck. Rubber is all the same, and glass, and most other stuff! I had 2 55 drums, but they are diff than the 53 and earlier ones. Think you'll be going to yards to find rears to get a drum off. Easier to take off the whole hub by the big nuts under axle than to take off the drum only. Some of those had three flat head screws, but very hard to get out. Wouldn't think they would charge much for the part, it won't fit more modern axles like 54 up will.
G.L. Grumpy's Old Iron Ranch Huntington, IN 46750
MM R tractor, Speedex and Power King tractors
| | | | | Joined: Dec 2003 Posts: 265 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 265 | Thanks G.L. I'll order the cab stuff tomorrow and see if I can find a yard with an old axle. The older ones must be an inch larger because everyone can find the 15" but not the 16" | | | | | Joined: May 2003 Posts: 90 Member | | Member Joined: May 2003 Posts: 90 | Hi-
I thought I would put feelers out here for 2 ton truck parts.
I have a 1.5 ton truck that needs a cab. I have found 2 complete 2ton Chevy trucks for free that have decent tin on them. I will need to cut the frame in half behind the cab to even get these trucks. I don't have a trailer big enough to haul these complete.
Since I only really need one of the cabs, What is the market for the fenders, grills etc. for these bigger trucks. I would like to recover some of the costs to go out and get em.
Also, what are people really looking for on parts for these trucks. Any rear ends or ??? Is anyone willing to come and get the parts for these big trucks if you offer them for sale because of the hassle and shipping costs involved?
I live in Colorado.
Brent
Thanks for any input. | | | | | Joined: May 2003 Posts: 90 Member | | Member Joined: May 2003 Posts: 90 | I forgot to mention these trucks are 49->52 trucks. Thanks,
Brent | | | | | Joined: Feb 2000 Posts: 587 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 587 | Not a big market for bigger parts, as you know, shipping becomes the barrier. Fella above needed a drum? What you got? Save a brake boooster if it's good, always need those! PTO's and trans with brakes are keeper parts, maybe the drive shaft of fittings anyway if you have room to keep. Wheels with good tires on them, you can change one piece are a plus. Don't be afraid of cracks in the rubber on tires, they last long time!
| | | | | Joined: May 2003 Posts: 90 Member | | Member Joined: May 2003 Posts: 90 | Thanks,
That is kinda what I thought. I will give it some thought on what I will keep. As for drums and stuff I feel for the guys that need the parts cause I have been in that situation but 3 hours of my time doesn't warrant a 20 dollar drum.. Ya know what I mean? Not to sound cold.
I will see what it take to get the rear axles. If a tractor is around I might grab em.
Brent | | |
