1 members (homer52),
66
Mod | | | Forums66 Topics128,072 Posts1,055,906 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2009 Posts: 639 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 639 | Does ANYONE carry the brass junction block that mounts to the back of the master cylinder on a 1953 half ton pick up? I have to replace mine ASAP. My truck is a daily driver and I'm to leave on a road trip the end of this month. I have checked every single supplier I can think of and no one carries that particular part. | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | I have several used ones removed during street rod conversions. All those go to a dual MC so I try to save as much as I can for the originality guys. PM me if interested. You are referring to the one that is held to the back of the MC with a hollow ported bolt and two copper washers aren't you?
Evan
| | | | | Joined: Nov 2009 Posts: 639 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 639 | Yes sir, that's the part! I'll send you a PM here in a minute. Thanks! | | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | twotone Did you know they call that a banjo fitting...brake banjo,has rings to help seal it up !! | | |
