7 members (Chip O, Otto Skorzeny, klhansen, Peggy M, MrSnerdly, carbking, Ponchogl), 160 guests, and 1 robot.
Topics128,034
Posts1,055,541
Members48,425
#1406984 04/21/2021 6:58 PM
Is it possible to remove the bell housng with the engine still in the truck? It's a 51 3800.
John L. #1406990 04/21/2021 7:48 PM
The rear engine mounts are on the bell housing, so likely not easily. If you supported the engine, removed the tranny, etc. I suppose it could be done. But the short answer is No.
John L. #1406992 04/21/2021 8:19 PM
Only reason I could see would be to replace that rear block core plug. Yes, support the engine, remove transmission, clutch, flywheel & there you go!
BC
1960 C60 pasture art
