2 members (Otto Skorzeny, Charles in CA), 79 guests, and 0 robots.
Topics128,051
Posts1,055,764
Finally going to install my Langdon HEI I bought eons ago for my 55 3200 with a 235. In the instructions it says to set timing at 10-18 degrees BTDC before dropping in distributor. I located the ball bearing and pointer and lined them up for TDC. My question is approximately how far is the bearing offset from the pointer to get the 10-18 degrees ( 1/4" for example) I don't see any degree marks on the flywheel. Any help appreciated.
AD Addict & Tinkerer
You could use a timing light that has the advance timing feature.here is one from Amazon. https://www.amazon.com/Innova-3555-...mp;psc=1&refRID=X1B8PT4VDQRK3RGXGRPT
Phil
Project Journals
Stovebolt Gallery Forum
