3 members (dt235sd, cmayna, Hotrod Lincoln), 102 guests, and 2 robots.
Topics128,142
Posts1,056,490
Members48,442
#1406656 04/19/2021 1:37 PM
Just wondering where it is.
I found this one painted over, but it appears to just be the VIN.
There was no "trim tag" on 1953 Chevrolet trucks.
There was an Engine Serial Number and a Vehicle Serial Number - 1953 serial numbers would be the same locations.
Here is information about 1953 car/truck serial numbers.
Then how does one determine correct paint code?
You'll need to find a spot with original paint and use the tech tips to match it up with one of the optional factory paint colors. Underneath the outside mirror arm is usually pretty close to original.
This can be helpful also.
1953 Chevrolet Truck Paint Names
Maybe someone else knows if they had codes/numbers?
The link I posted has various manufacturer's paint codes for most of the colors used.
Sorry, Kevin - - paintref.com is excellent - - thanks
here are some paint codes on my website - I have not updated that page in about 15 years.
