1 members (WICruiser), 209 guests, and 1 robot.
Topics128,102
Posts1,056,184
Members48,436
#140675 01/02/2005 6:32 PM
Junior Member
Junior Member
just posted a topic on my truck not starting after i weld on it.
i posted some pics that i had here at home on a web site, i will take a bunch more next time i get to the farm.
the green truck is the one i am putting a dirt box on, the excavator is an ebay purchase to dig ponds, and the 1958 chevy is my father in law buying another old truck from another old guy.\
[img]http://www.villagephotos.com/pubbrowse.asp?folder_id=1163305[/img]
#140676 01/02/2005 6:34 PM
Junior Member
Junior Member
#140677 01/02/2005 6:36 PM
Junior Member
Junior Member
man i suck at this. the topic on my truck not starting is in the engine and driveline forum but is should be here.
#140678 01/02/2005 8:09 PM
You are doing okay fine. This actually is pretty easy once you do it a few times. I did move your post about the truck not starting to the Big Bolts forum.
If you have any ?? about using the forums, on the intro page, there's a pretty good FAQ section. Norselander even did a good job making some images with arrows and everything.
And ... while we're here ... welcome!!
Peggy M
~ One of many.
#140679 01/02/2005 10:23 PM
Are you getting spark when it doesn't start? The only thing I can think of is the points maybe getting damaged some how. May also just be a coinsidence too,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#140680 01/03/2005 2:23 AM
who gives a rip about the truck - I want that excavator!
Life's short - don't waste it.
#140681 01/03/2005 10:13 PM
Big Bolt Shop Curmudgeon
I'll leave the analysis to the welder experts, but I would offer this comment.
Make 100% sure that your welding ground is as close to what you are welding as possible and that you are not getting any transient amperage running around throughout the truck frame and electrical system.
Welding currents wandering around looking for the ground will fry the coil, points, regulator and anything else that can be discovered.
But thow can that be? Well, trucks are fraught with rusty connections that divert electrons from intended paths, and welding amperage will walk through rust and look for unintended paths of least resistance.
Drivin' down a 2 lane country road in a stovebolt.....cowboy, it don't get no better than this!
1946 1-1/2 ton Chevy
"Ol Blue", or "THE BIG 'UN"
