3 members (Chris's 46 / 515, Rusty Heaps, 2-Ton), 154 guests, and 3 robots.
Topics128,080
Posts1,055,950
Members48,430
#1405816 04/13/2021 12:07 AM
I'd like some input on tubes: what would be the best source/manufacturer for tubes for 7.00-20 bias tires? I would like them to be radial type and American made, but I'm probably dreaming. They need to have the long bent type valves. My quick online checking shows that there may still be (?) some US-made radial tubes in the 7.50-20 size, but I would assume that it would not be advised to use a larger tube. I've had bad luck with 'modern' bias tubes. I'd sooner put a good used bias tube made in 1950 in one of my tires than most of them made now. Your thoughts and advice appreciated!
1955 GMC 630, 1959 GMC W660, 1958 Chevy Spartan 80
Former Workshop Owner
Not sure if this is any help, but I just purchased tubes for my riding mower at justubes.com. I placed my order on Thursday night and received my tubes on Sunday via Fed Ex with free shipping.
~ J Lucas
2006 GMC Envoy 4.2 I6
2023 Ram 2500/Cumins 6.7 I6
2002 Silverado 2500 Gas 6.0
1941 Chevy 1/2-Ton
1942 Chevy 1.5-Ton SWB
My Flicker Photos!
jaycoop #1405878 04/13/2021 10:17 AM
I've bought tubes from M.E.Miller tire ( https://www.millertire.com/) and Coker ( https://www.cokertire.com/ ) I don't know about the Coker tubes yet but I've been happy with the Miller tubes.
Larry Kephart
1937 Chevy Utility Express (Deerslayer)
1955 1st 3100 Chevy (BillyBob)
2017 Cadillac ATS-V (Elvira)
Boca Raton, Florida
e-mail: [email protected]
http://www.laroke.com/larryk4674/1998/billybob.htm
Thanks John and Larry, I'll check those sites.
Check tswarehouse on ebay. I just bought 4 tubes 8.25xR20. $27.00 and free shipping
I'll check them out also....thanks!
Jaycoop You'll be lucky if you can land American tubes the radial ones are just thicker I think. If you go to a bigger tube will wrinkle-up,I don't know where to get soapstone but that would help ! We used to pump-up new ones then let em go down and re-fill to help on wrinkles !
The tubes I bought have a powder coating that helps prevent wrinkles and let's the tubes slide inside the tire during inflation
If your tubes aren't coated in powder you can always use your own Baby Talcum Powder to coat the inside of the tire to help prevent wrinkles...that's the way the old tire shops did it.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Crusing in the Passing Lane
Talcum powder is what I use?
Ed
jaycoop #1407048 04/22/2021 11:42 AM
62401
"They" always say to get new flaps with your new tubes. New tubes -- new flaps. Is this actually necessary?
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
My tire shop reused the old flaps except 1 that had a bad spot in it. Their not really a wear item just a liner.
If you have rims that use a locking ring to secure the rim pieces together, i.e. split rims do not attempt to replace the tires yourself. That locking ring can pop off and easily maim or kill you!! Tire shops put the wheel in a cage when inflating to prevent injury.
Moderator
Moderator
2 Online: Content
I will mount my own tires on multi piece rims.
Make sure all the parts are clean and fit good.
Wrap the tire and rim thru to rim holes with a long log chain, then use a clamp on air chuck and a pressure regulator.
Pump up to about 15 psi. Hit it some good licks with a sledge hammer. The tire not the rim.
30 psi next and beat it again.
Repeat stepping it up 15 to 20 psi until you reach your desired psi.
The sledge also helps get any wrinkles out of the tube. Talcum powder is also used.
If the old flaps look ok, I just reuse those.
Don
"The Flag Pole"
1946 2-Ton grain truck
1946 3/4-ton pickup,
1953 1-ton pickup
1957 1-ton flatbed dually,
1954 Pontiac Straight Eight
