1 members (Shade Baby),
147
0
Mod | | | Forums66 Topics128,162 Posts1,056,940 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2007 Posts: 226 'Bolter | | 'Bolter Joined: May 2007 Posts: 226 | I have a 1964 327 in a 1957 Chevy 1/2ton. I’m using Chevy rams horns exhaust manifolds. The drivers side manifold has two holes in the front of the casting that I assume are for an alternator mount. Can anyone tell me what that mount looks like and what part number I need?
Thank you, Larry | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | Both the 57 and 64 V8 engines had generators. If you do a search for sbc short water pump alternator mount kit there will be a number of hits. Alan Grove has bare steel kits that are lower priced than the chrome/stainless/billet ones.
Evan
| | | | | Joined: May 2007 Posts: 226 'Bolter | | 'Bolter Joined: May 2007 Posts: 226 | Thank you. I looked at the Alan Grove site and they do have a lot of options. I’d like to utilize the driver side exhaust manifold holes to create something out of the pile of brackets that I have, but maybe it will be simpler to go aftermarket. | | | | | Joined: Mar 2007 Posts: 3,438 Crusty Old Sarge | | Crusty Old Sarge Joined: Mar 2007 Posts: 3,438 | I used this one from Speedway, it designed to use with headers but I'm sure you could fab up something close to work with your manifold. https://www.speedwaymotors.com/Small-Block-Chevy-Alternator-Slide-Bracket,18433.html
~ Craig 1958 Viking 4400"The Book of Thor"Read the story in the DITY1960 Chevrolet C10"A Family Heirloom"Follow the story in the DITY Gallery'59 Apache 31, 327 V8 (0.030 over), Muncie M20 4 Speed, GM 10 Bolt Rear... long term project (30 years and counting) If you don't like driving yourTruck, you won't drive yourTruck..| Living life in the SLOW lane | | | | | Joined: May 2007 Posts: 226 'Bolter | | 'Bolter Joined: May 2007 Posts: 226 | Thank you. I’ll check that out.
Larry | | | | | Joined: Aug 2001 Posts: 3,608 Moderator | | Moderator Joined: Aug 2001 Posts: 3,608 | Just seen this thread. I bought a 57 GMC one ton a few years ago and it has the 327 cobbed in it. I'll try and get some pictures posted tonight.
Don 1967 GMC 9500 Fire Ladder Truck"The Flag Pole"In the Stovebolt Gallery1946 2-Ton grain truck 1946 3/4-ton pickup, 1953 1-ton pickup 1957 1-ton flatbed dually, 1954 Pontiac Straight Eight Of all the things I've lost in my life, I miss my mind the most! | | | | | Joined: May 2007 Posts: 226 'Bolter | | 'Bolter Joined: May 2007 Posts: 226 | | | | | | Joined: Apr 2005 Posts: 2,101 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,101 | 63 up 283 & 327 engines used an alternator with a bracket that mounted on the front side to the two staggered holes on the left rams horn manifold. The bracket held the lower part of the alternator with an extension of the bracket attached to the (short) water pump. The adjustment bracket attached to the front of the intake similar to the one used on a 57. I think I have them somewhere. Fred
| | | | | Joined: May 2007 Posts: 226 'Bolter | | 'Bolter Joined: May 2007 Posts: 226 | Hi Fred. I’m very interested. Please let me know. Thanks, Larry | | | | | Joined: Apr 2005 Posts: 2,101 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,101 | Larry, Please send me a PM with your email address. Thanks, Fred
