2 members (pdlightning, Tronman), 104 guests, and 3 robots.
Topics128,094
Posts1,056,064
Members48,433
#1405741 04/12/2021 1:15 PM
Morning all.
The engine in my 53 3100 is stuck from sitting.
Should I pull the dizzy and pre-lube it, or just put a strap on it and pull it slowly in third behind a tractor?
BTW, read our Tech Tip on waking up a stuck engine. You’ll save yourself some $
Definitely check out the tech tips. I'll leave this post here for now so that the new 'bolters can see where to go.
Another quality post.
Real Trucks Rattle
Oops...got in a hurry...
That doesn't sound good!
BC
1960 C60 pasture art
Glad you posted this actually. I'm in the same boat and read through the Tech Tips that was linked into this thread. Lots of great info here. Good luck with your engine.
~ Cameron
1956 3100 Task Force
Follow the build in the DITY
Went out, pulled all the plugs (all clean and an even shade of light gray) shot a BUNCH of penetrating oil in the cylinders and put the plugs back in.
Will let that soak a few days.
Good Luck! A solution to your problem I've long wanted to try is; park the truck on a pretty good hill. Pull sparkplugs and pore several ozs of Coke in each cylinder. Then with the transmission in high gear walk away for a few days. When the truck is at the bottom of the hill you'll know the carbonic acid in the Coca-Cola has done it's job of dissolving the rust that had rust-welded the pistons to the cylinder walls.
RonR
RonR
1970 340 Duster
1964 CJ5
Interesting idea Ron.
Brian
1955.2 3100 Truck
Make sure there's not a busy road at the bottom of the hill!
Make sure your gas is disconnected. Because it could bump start on you and end up miles away if it’s a straight road at end of hill. 😀👍
That would be a memorable end to the story smile. However you need to leave the sparkplugs out so compression isn't a factor when the rust breaks loose and it rolls down the hill.
RonR
RonR
1970 340 Duster
1964 CJ5
