6 members (Gdads51, Bill Hanlon, Buckeye998, fonz8261, Shade Baby, BarryP), 329 guests, and 4 robots.
Topics128,163
Posts1,057,072
Members48,463
#1405670 04/11/2021 10:08 PM
I have more zippers then a pair of cargo pants
Where can I find all three front spring bushings and the pins/bolts that go with them for a 51 Chevy 1 ton panel. According to my spring shop in St. Louis they can’t get or don’t have the front ones that have the threads in them. So I might as well find a source for all three. Thanks in advance...,joe
~ Joe
Donate Blood, Plasma, Platelets and Sign Your DONORS CARD. The Life You SAVE Might Be Someone You Know and LOVE.
Two possibilities exist: Either we are alone in the Universe or we are not. Both are equally terrifying. ~ Arthur C. Clarke
Not yet but I will. Thanks
~ Joe
Is a 1 ton a 3800 and do they look like this
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
2 Offline
the front spring bushings for a 3800 are the same part used on the rear suspension of the lighter trucks
so many places have them but don't list compatibility, but if you know exactly what you are buying it will work because it's the same part based on the part numbers in the books.
7.413 Bushing, front spring eye
41-55 D-D, 1 Ton part# 3651131 (2 per)
this is a smooth plain bushing
7.428 Bolt, front spring
41-55 D-D, 1 Ton part# 3657393 (2 per) (this is on the front of the front spring on the D-D)
this is a smooth bolt with grease hole for bushing,
classicparts and chevs of the 40s carry this part
7.104 bushing, spring hanger
this is the special threaded bushing that screws onto the threaded pin
41-55 1 Ton, "shackle" 499533 (4 per)
this part also appears in group 7.524 bushing, rear spring:
55-57 1/2 & 3/4 Ton (2nd ser.) rear spring shackle (4 per)
classic parts - 74-021 $40 each (washers included)
LMCtruck - 34-1362 2nd ser. rear suspension shackle $30 each (plus $6 for washer set 34-1406)
LMCtruck - 34-1354 1st ser. rear suspension shackle $25
7.427 pin, front spring shackle
41-55 1 Ton part# 3653273 (4 per)
7.436 shackle, Front Spring
47-52 1 Ton part# 3847460
substitute 3847460 --> 3741083 as of 3-1-58
60-62 D-D (exc. 102 W.B.) Shackle unit 3471083
47-54 COMM., UTIL. (exc. D-D, COE) front (4-1/16 O.L.) 3682788
55-58 COMM., UTILITY (2nd ser.) 4-1/16 O.L 3682788
7.523 Shackle Unit, Rear Spring
55-56 1/2, 3/4 TON (2nd Ser.) (exc. D-D) Shackle Unit 3847460
55-59 1/2, 3/4 TON (2nd ser.) (exc. D-D) (4-1/16 O.O.) 3682788
7.443 washer
34-52 part# 593705
chevs of the 40s - 3653273 rebuild kit - pins, bushings and washers for both sides $103
chevs of the 40s - 3847460 whole shackle assembly 1 side $118.39
chevs of the 40s - 593705 washer set for both sides $14.75
Th reason I posted this is rock auto has this under half ton but says 3800 also and if you check out there price on theses it may be worth getting one to see if they are the same.
"The Journey"
Follow in the DITY
2 Offline
That’s the rear spring pin tho the fronts are all smaller different.
FYI that rear bushing is very standard size
Much cheaper to buy it as a generic bushing
Only spend on the pin
-s
Mine are a little different for the half ton but rock auto has theses for 12.50 mine were 10.00 which is a good price ,don’t know what the difference in others on the same site that are a lot more they also have the bushings and pins that screw into each other for a good price if anyone needs them
"The Journey"
Follow in the DITY
Those are the rear pins and bushings.... joe
~ Joe
I’ll have to say, all those numbers confuse me just a bit. Can you show me just the part number four the shackles and the pens for the front leafspring so I make sure I have the correct ones...... thanks joe
~ Joe
Here are the part numbers:
- Front leaf spring front mount shackle kit, Moog K150240 or AC Delco 45G13044. These are the complete shackle kit that includes bushings, pins, shackle, rubber gaskets and nuts. This is the newer style that doesn’t require the center bolt.
- Front leaf spring rearward mount, AC Delco 45G17017. This includes the bushing, bolt, nut and washer.
These part numbers are on Rockauto. You will require two of each. If you want NOS, then you will have to sift through the part numbers above.
I sent you a PM.
Dave
1966 Chevrolet Caprice 2 Door Hardtop (396 Big Block)
1951 GMC 9434 5 Window (waiting on a 292 transplant)
I sent you a PM.
Dave
Any chance that the Delco 45G13044 would work as a rear spring rear shackle for a 1/2 ton? Looks pretty similar except for the lack of center bolt.
1951 3100
JW51 #1406229 04/15/2021 6:30 PM
Shackles are different between front and rear springs. The differ in the length of the shackle (rear has longer side bars.) But I suppose you could use a front shackle on a rear spring. It would drop the rear of the truck by maybe 1/2" (WAG.) The bushings on 1/2 ton shackles are the threaded ones. The fixed mount to the frame (rear of front springs and front of rear springs) are the smooth bushing and bolt with grease fitting in the end.
JW51 #1406235 04/15/2021 7:05 PM
Rock Auto show AC Delco 45G13042 as the rear shackle for half ton, you would have to confirm.
Dave
Moderated by  Dusty53
