| | | Forums66 Topics128,089 Posts1,055,988 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#14057 04/25/2002 2:30 AM | Joined: Dec 2001 Posts: 15 New Guy | | New Guy Joined: Dec 2001 Posts: 15 | Got a 55' 2nd with a 235. How man quarts of oil does it take if you change oil/filter? Also, should I pour oil in the filter canister when I replace the cartridge, or should I just let it re-fill from the crankcase?
Anybody know if Napa, etc..... carries the replacement filters, or do I need to order one from ChevyDuty? Thanks. Curt | | |
#14058 04/25/2002 3:40 AM | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | Napa had filters for 235. They were over 7.00 dollars apiece when I last priced them 7-8 years ago. I believe the 235 holds 5 quarts.  | | |
#14059 04/25/2002 5:11 AM | Joined: Sep 2001 Posts: 272 Shop Shark | | Shop Shark Joined: Sep 2001 Posts: 272 | For my 56 235 I got a filter from NAPA about 3 months ago. They had it in stock too. about $9. Had to go to another location not all stores carry them, may have to have one located at another store for you. Brad  | | |
#14060 04/25/2002 5:17 AM | | Anonymous Unregistered | | Anonymous Unregistered | 5 quarts without the filter. If you have the 1 quart filter bolted to your intake manifold its about 6.50 quarts. The Napa filter # for your 1 quart cannister filter is #1006.  | | |
#14061 04/25/2002 5:17 AM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | 6 quarts with the filter. And it really doesn't matter on the 235 if the filter is dry or not. It's a bypass filter (unless someone has modified the engine), and it is not in the line to lube the engine. Oil for the filter is tapped of the distribution rack, goes through the filter, and back into the engine. Not even that much difference if all the oil is pumped through the filter. When you start a full flow engine after a filter change there is enough oil left on the bearing surfaces to idle for a few minutes before any damage will occur. Do you ever fill the filter on your car when the filter is at an angle behind the exhaust manifold and above a wire bundle? Neither do I.
Fred 52 3600 69 C-10
#14062 04/25/2002 8:03 PM | Joined: Mar 2001 Posts: 77 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Mar 2001 Posts: 77 | if you have the full flow filter system and the filter hangs down.
yes do fill your new oil filter with oil every time you change oil that will give your engine a head start
i thinkzz traveling along at terminal velocity will soon wear a body out. i will not die in shame if i never finish my dreams because my family iz my reality
can't wait until we can bed de ponys down, lite de fire, put on a big ol pot of coffee, and talk about how strong and brave our teams are.
bullfoot thinkszzzzzzzzzzz
#14063 04/25/2002 11:16 PM | Joined: May 2001 Posts: 1,904 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,904 | Mine holds 6 qt. with the filter (Fram C4P or something like that). The filter is the only thing that I'll buy at our Checker Auto Parts. They always have one and only one. I always fill up the filter canister before capping it because I'm superstitious, I guess. 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
