3 members (dunfire, MikeE, carbking), 55 guests, and 1 robot.
Topics128,129
Posts1,056,360
Members48,441
#1405643 04/11/2021 8:17 PM
I have a 1951 Chevy 3600. It has been converted to 12 volt. The gas gauge (original) has worked fine up until about a year ago, then just stopped working. When I turn the key from the dead position to accessory position the gauge will “jump” or “twitch” slightly, then return to where it is frozen, at about the quarter full mark. Does this sound like an electrical problem, or the float is bad inside the tank.....or what?
Pickmeup #1405680 04/11/2021 11:33 PM
Moderator, Electrical Bay
Most likely it is your sending unit (inside the tank). If you'll search under this section, you'll see I've done a lot of work on this. If you have the original sender, I can pretty well promise you it has just given up the ghost. If you have one of the foreign-made replacements, I can without doubt promise you it has given up the ghost. Please let me know if you need more info on this.
~ Jon
Pickmeup #1405710 04/12/2021 1:55 AM
Sir Searchalot
Sir Searchalot
YES.
Pickmeup #1406693 04/19/2021 6:56 PM
Did you install a drop-down resistor on the power wire to the gas gauge? I agree that the original gauge and sender will function on 12 volts. The only question is how long.
Rusty
Pickmeup #1406694 04/19/2021 7:11 PM
It is actually a Runtz style voltage reducer.. It must be installed in the correct "direction". Just disconnect the existing line at the gauge and connect the reducer - that will assure correct direction.
an explanation
here is another one
