| | | Forums66 Topics128,080 Posts1,056,062 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2021 Posts: 5 'Bolter | | 'Bolter Joined: Jan 2021 Posts: 5 | I have a 1951 Chevy 3600. It has been converted to 12 volt. The gas gauge (original) has worked fine up until about a year ago, then just stopped working. When I turn the key from the dead position to accessory position the gauge will “jump” or “twitch” slightly, then return to where it is frozen, at about the quarter full mark. Does this sound like an electrical problem, or the float is bad inside the tank.....or what? | | | | | Joined: Mar 2014 Posts: 4,489 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,489 | Most likely it is your sending unit (inside the tank). If you'll search under this section, you'll see I've done a lot of work on this. If you have the original sender, I can pretty well promise you it has just given up the ghost. If you have one of the foreign-made replacements, I can without doubt promise you it has given up the ghost. Please let me know if you need more info on this.
~ Jon 1952 1/2 ton with 1959 235 | T5 with 3.07 rear end
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Does this sound like an electrical problem, or the float is bad inside the tank.....or what? YES.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Mar 2019 Posts: 119 'Bolter | | 'Bolter Joined: Mar 2019 Posts: 119 | Did you install a drop-down resistor on the power wire to the gas gauge? I agree that the original gauge and sender will function on 12 volts. The only question is how long.
Rusty
