3 members (frogfarmer, MNSmith, 1 invisible),
51
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,090 Posts1,056,024 Members48,432 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2018 Posts: 106 'Bolter | | 'Bolter Joined: Oct 2018 Posts: 106 | I can't find a manual for my '54 6100. What all is involved in removing the radio and speaker for replacement? | | | | | Joined: Jul 2000 Posts: 2,192 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,192 |
Gord 🇨🇦 ---- 1954 1/2 ton 235 4 speed | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | This YouTube video might help to understand.The "front plate" in front of the "dial" goes outside the dashboard and, the radio goes behind the dashboard and, the two radio posts go through the holes in the dashboard A washer and nut goes around each post; and, the knobs get pushed onto the posts. If the knobs are loose on the posts, the post ends can be carefully/slightly opened. If this is incorrect or this is not clear, maybe someone will correct or add information/instructions. I'll see if I can find the original installation instruction. | | | | | Joined: Oct 2018 Posts: 106 'Bolter | | 'Bolter Joined: Oct 2018 Posts: 106 | | | | | | Joined: Oct 2018 Posts: 106 'Bolter | | 'Bolter Joined: Oct 2018 Posts: 106 | This YouTube video might help to understand.The "front plate" in front of the "dial" goes outside the dashboard and, the radio goes behind the dashboard and, the two radio posts go through the holes in the dashboard A washer and nut goes around each post; and, the knobs get pushed onto the posts. If the knobs are loose on the posts, the post ends can be carefully/slightly opened. If this is incorrect or this is not clear, maybe someone will correct or add information/instructions. I'll see if I can find the original installation instruction. Thanks, That helps a lot. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Thanks for the photo, Brad - you posted them while I was typing my post. | | |
