2 members (Eileen, 1 invisible), 80 guests, and 3 robots.
Topics128,079
Posts1,056,310
Members48,442
#1405466 04/10/2021 2:17 PM
The door on my truck is not closing correctly. It's. Too low on the latch side. Can the hinges be shimmed . Help is appreciated. Thanks larrym
AD Addict & Tinkerer
You should be able to make adjustments instead of shimming. I’ve linked the door adjustment procedure from the Chevrolet Truck Shop Manual.
http://chevy.oldcarmanualproject.com/shop/1947truck/47ctsm0109.htm
It could also be worn hinge pins which are replaceable and available from most vendors.
Phil
Project Journals
Stovebolt Gallery Forum
Thanks but the instructions for. A 1947but are not the same.
I believe 1939 to hru 1946 are same hinges. My truck is a 1940. Thanks larrym
larrym,
Shoot me an email and I can send you some pages out of a 46 GMC manual that shows how to adjust the doors. Worked great on my 46.
George
My bad! Here is another link for a “1941 Chevrolet Shop Manual for Passenger Cars and Trucks”. I don’t know if it’s applicable to your truck but worth a try.
http://chevy.oldcarmanualproject.com/shop/1941/41csm030.htm
Phil
Project Journals
Thanks larrym
