3 members (Otto Skorzeny, msmall, 1 invisible),
143
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,137 Posts1,056,471 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2007 Posts: 8 'Bolter | | 'Bolter Joined: Feb 2007 Posts: 8 | The door on my truck is not closing correctly. It's. Too low on the latch side. Can the hinges be shimmed . Help is appreciated. Thanks larrym | | | | | Joined: Feb 2019 Posts: 4,486 AD Addict & Tinkerer | | AD Addict & Tinkerer Joined: Feb 2019 Posts: 4,486 | You should be able to make adjustments instead of shimming. I’ve linked the door adjustment procedure from the Chevrolet Truck Shop Manual. http://chevy.oldcarmanualproject.com/shop/1947truck/47ctsm0109.htmIt could also be worn hinge pins which are replaceable and available from most vendors.
Phil Moderator, The Engine Shop, Interiors and Project Journals1952 Chevrolet 3100, Three on the Tree, 4:11 torque tube Updated to: ‘59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc BrakesProject JournalsStovebolt Gallery Forum | | | | | Joined: Feb 2007 Posts: 8 'Bolter | | 'Bolter Joined: Feb 2007 Posts: 8 | Thanks but the instructions for. A 1947but are not the same. I believe 1939 to hru 1946 are same hinges. My truck is a 1940. Thanks larrym | | | | | Joined: Mar 2000 Posts: 784 'Bolter | | 'Bolter Joined: Mar 2000 Posts: 784 | larrym,
Shoot me an email and I can send you some pages out of a 46 GMC manual that shows how to adjust the doors. Worked great on my 46.
George | | | | | Joined: Feb 2019 Posts: 4,486 AD Addict & Tinkerer | | AD Addict & Tinkerer Joined: Feb 2019 Posts: 4,486 | Thanks but the instructions for. A 1947but are not the same. I believe 1939 to hru 1946 are same hinges. My truck is a 1940. Thanks larrym My bad! Here is another link for a “1941 Chevrolet Shop Manual for Passenger Cars and Trucks”. I don’t know if it’s applicable to your truck but worth a try. http://chevy.oldcarmanualproject.com/shop/1941/41csm030.htm
Phil Moderator, The Engine Shop, Interiors and Project Journals1952 Chevrolet 3100, Three on the Tree, 4:11 torque tube Updated to: ‘59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc BrakesProject JournalsStovebolt Gallery Forum | | | | | Joined: Feb 2007 Posts: 8 'Bolter | | 'Bolter Joined: Feb 2007 Posts: 8 | | | |
