Fixing the old truck
BUSY BOLTERS
Are you one?
Where is it?? The Shop Area
3 members (Woodcmiami, newtonlr, moparguy), 613 guests, and 1 robot.
Topics126,776
Posts1,039,259
Members48,100
Most Online2,175
Jul 21st, 2025
#1405340 04/09/2021 1:50 PM
46 Chevy 1/2 Ton 1929 Model A Phaeton
I have a 46 Chevy 1/2 ton that has been professional restored. It has an annoying tendency to wander while I'm driving. I know this can be caused by many problems but I have had 2 people tell me that replacing the current 6.70-15 4 ply polyester tires with modern radial tires would make a huge difference in handling. I was told radial tires with modern roads are much better than the old style tires. Has anyone replaced polyester tires with radials and experienced a big improvement in handling?
Back in the 70s when I sold tires our training told us that radials did not follow the imperfections in the road whereas poly and other bias ply tires followed everything causing a lot of unnecessary steering input.
AD Addict & Tinkerer
My truck wandered so badly it was like “trying to herd cattle down the road” (a phrase I stole from HRL) and my truck came with radials. It wasn’t until I fixed a worn spring mount, rebuilt the springs, replaced the king pins, tie rod ends and adjusted the steering box that I got her tamed down. I’m not saying you’ll have to replace everything that I did, but any one of those items can cause your truck to wander.
Now bias ply tires as you probably know will pull you from side to side when crossing inline cracks, but they shouldn’t cause you to wander.
Jack up the front of your truck and move things around (wheels, tie rods, steering box, etc.), and see if anything has any play. Also wheel alignment plays into it. Read about adjusting your steering box. It’s a fairly easy procedure and can cause the wandering your talking about.
Here is a link on adjusting your steering box.
http://chevy.oldcarmanualproject.com/shop/1942_47/4247csm901.htm
Phil
Project Journals
Stovebolt Gallery Forum
thank you both for the input.
I converted my '37 half ton, '51 half ton and '50 2 ton COE from bias tires to radials. In all cases I drove the trucks before and after the conversion without other interventions (like adjusting steering or replacing suspension parts) and the improvement in handling was dramatic. I also bought new bias tires for my '42 half ton, which I have owned for over 20 years, and that also improved handling dramatically. Clearly, new thicker tread helps in handling in both types of tires but you won't be disappointed with the radials.
Kent
1937 Chevy 1/2 ton
1942 Chevy 1/2 ton
1947 Diamond T Model 509
1951 Chevy 1/2 ton
I have radials on 1954 1/2 ton and put them almost from the beginning back in 1983, I would not have anything else. The bias tires would jump lanes. I had polyglas added on my 1969 Plymouth Sport Fury for the same reason. The polys were the forerunner of radials. I even paid extra when I bought the Plymouth new.
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
Tires are probably last on the list of what it is. I have seen pros not do alignments or leave stuff loose. 1/2” of toe out will make a truck drive like the worst junk you could imagine..... then a few turns to 1/8” toe in and it will cruise with 1 hand on the wheel and float down the road with almost no steering input. Are radials better? Yes....... but they might not fix your problem even though some one automatically told you thats your problem.
W Online: Content
After I switched from bias to radials, I could bring a cup of coffee with me to work without the coffee sloshing out.
33 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
thanks everyone for the info. I think I'll start with checking out the steering components. Then try to find someone that can align the front end. If that works I'll save money on the tires. If it doesn't work, I'll spend the money for the radial tires.
Sounds like a good plan Fred.
Brian
1955.2 3100 Truck
Bond Villain
Bond Villain
Yet another opinion ... smile
Fred, I am running (new) bias ply tires on my truck. I have made a few upgrades (rear axle gearing, engine upgrade to a 261) that now allow me to cruise comfortably at 60-65 with dashes to 70 comfortable, as well. Thanks to Sweet and others, my steering has been adjusted to specs (adjustment to alignment as well as the steering box). I find that the truck steers just fine.
I have *not* replaced my tie rod ends. My truck has less the 65k miles on it, and steers just fine with everything else adjusted properly so I'm kicking *that* can down the road a little further ... smile.
Radials obviously and without debate give you a better ride and steering. But, with all other things being equal (i.e., a few adjustments and tweaks), bias plys can do an adequate job. Depends on your driving habits and how much you plan to drive the truck.
Don't get me wrong here -- If I could keep my stock appearing wheels (and hubcaps) without spending ginormous amounts of cash on wheel mods, I would be running radials today. But I can't afford the mods to make the 17-inch wheels work for my truck, so I am stuck with the bias plys. And I find they work pretty good. Not as great as radials, but not too bad. They remind me to keep it under 70. smile
I would think/hope you would want to make sure your steering/alignment is all up to spec anyway wink. And while we're at it, don't forget to throw some love at your brakes. Have you installed some seatbelts yet? If we're talking driving on modern roads here at modern speeds (or there abouts ...), let's be sure we're safe smile
~ John
"We are not now that strength which in old days
Moved earth and heaven; that which we are, we are"
1948 International Farmall Super A
1949 Chevrolet 3804
1973 IH 1310 Dump
2014 Ford E-350 4x4 (Quigley)
Take a quick look at the front springs where they mount to the axle, does it have CASTER wedges and are they pointing the right direction? The wedge should have the thicker end towards the rear of the truck. With out the proper caster, your truck will be all over the road. How does the steering wheel return after making a turn?
I had bias ply tires on my 39 3/4 ton stake truck for 30+ years, replaced twice with new bias ply. Two years ago I switched to radial. I knew the difference in handling just backing out of the barn. Steering wheel turns a lot easier at a stand still too. The radials have a bias ply look to them.
Rick
1939 Chevrolet Stake Truck
(Release build 20240826)
Responsive Width:
PHP: 8.3.11 Page Time: 0.047s Queries: 14 (0.038s) Memory: 0.6624 MB (Peak: 0.7638 MB) Data Comp: Zlib Server Time: 2025-09-22 01:41:51 UTC
Valid HTML 5 and Valid CSS
