5 members (Forty9, 3B, TPR57C, Otto Skorzeny, DennisM), 123 guests, and 3 robots.
Topics128,026
Posts1,055,403
Members48,422
#1405353 04/09/2021 3:21 PM
Looks like I may need to replace my rear cab mounts. I have a 1950 4400 , and I would like to know how much clearance between back of the cab and the frame? My cab is almost touching the frame, there might be enough clearance to slide a dollar bill under it.
1950 4400
Joe Alan #1405370 04/09/2021 4:36 PM
Joe Alan #1405376 04/09/2021 5:44 PM
IIRC there are measurements in the Factory Assembly Manual. John
Correct. Per Section 1, Sheet 1.07, top of frame is 10" above the zero line, and top of floor is 11.88" above zero line.
Also Per Section 1, Sheet 3.12, the rear body mount shackle should be shimmed to "maintain -.76 +.06/-.0 Dim between floor panel and top of frame."
But if there's so little space, the rubber bushings in the body mount shackles are probably severely worn.
tclederman #1405407 04/09/2021 11:22 PM
I’ll check it out, thanks
1950 4400
klhansen #1405408 04/09/2021 11:26 PM
Yes I believe your right, thanks for posting that info
1950 4400
Joe Alan #1405417 04/10/2021 1:39 AM
Can’t find a mounting kit for 4400 but I did find one for 3600 .Do any of guys know if they are the same?
1950 4400
Joe Alan #1405418 04/10/2021 1:47 AM
The shackles and bushings are the same. The brackets are different for 3100, but the same for the bigger trucks, according to the Assembly Manual. If your shackles are still intact, you just need the rubber bushings, which are the same for all trucks.
