1 members (Hotrod Lincoln), 104 guests, and 2 robots.
Topics128,089
Posts1,056,004
Members48,430
#140515 11/03/2004 1:59 PM
I was cleaning the rearend of my dump truck last nite. And i noticed next to the driveshaft yoke on the rearend is a (for lack of words)a metal unit. It said, Eaton 12v. Is this a two speed rearend. If so how hard is it to hook up.
47.5 Loadmaster 5 window
48 Chevy 3600
69 GTO convertible
#140516 11/03/2004 4:03 PM
got a picture?
My 44 has a 52 rear 2-speed, but it's vacuum shift, so it was pretty obvious, big round vacuum diaphram on a sqaure box in front of the differential... I've got pics of mine if it would help...
About halfway down page
-Mike R.
#140517 11/03/2004 4:17 PM
Funny. Tell my teen son sometimes he has a two speed rearend. Slooow and slooower. grin Sorry, couldn't resist that one..
Bruce
Old Toy: Ol' Betsy stock 59 Apache SB Stepside (Gone but not Forgotten)
New Toy: 1962 Impala SS Coupe
The Driver: 1990 Toyota truck
#140518 11/03/2004 4:22 PM
Mike, Its in the same spot but it does not have a vacuum canister. Its more of a square box
48 Chevy 3600
69 GTO convertible
#140519 11/03/2004 9:07 PM
H Online: Content
Yes, it's a 2-speed. It is one of the later-model units that shifts with an electric motor rather than vacuum. They're not as smooth as the vacuum-shift types, but they're a little more reliable. You'll need a 2-position switch on the shift handle that swaps the hot and ground to the motor, and some wiring back to the rear end. I think I've got a wiring diagram in one of my truck manuals at the farm. Drop me an email when I get back there this weekend, and I'll scan you a copy.
#140520 11/04/2004 2:10 PM
Thanks for the help everyone. Jerry sent the E-mail
Thanks. Ray
48 Chevy 3600
69 GTO convertible
#140521 11/05/2004 11:56 PM
Maybe you can find an old truck in the junk yard with a two speed and grab everything you need, switch, plug and wires. don't forget the mounting bracket.
#140522 11/08/2004 2:16 PM
Good Idea.........
48 Chevy 3600
69 GTO convertible
#140523 11/23/2004 5:55 AM
If you find a truck that had an Eaton 2-speed electric shift, don't forget to get the speedometer reduction adaptor. It's a little round unit that screws inline with the cable on the back of the speedometer. It will have one electric terminal that gets 12v when you shift to High Gear this will keep your speedometer/odometer calibrated regardless of range. All Eaton 2-speed rears have the same reduction multiplier (1.36), so any truck with one will work. The High ratio will be stamped on the front of your rear. Multiply that number to find the low ratio (ie. 6.14 high has a 8.35 low).
Regards,
Mike Boteler
'56 4400 Stake
'56 6400 Stake
'56 8400 Wrecker w/Holmes 525
'56 9200 Tractor w/Allison Automatic
'57 10500 Fire Truck
Hughesville, MD
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
#140524 11/23/2004 1:38 PM
Thanks.........
48 Chevy 3600
69 GTO convertible
