0 members (), 78 guests, and 12 robots.
Topics128,021
Posts1,055,355
Members48,420
#1405206 04/08/2021 12:01 PM
Leo
Offline
Moderator
Moderator
I have a 1986 Chevy half ton. I put in a clock that was an option, lower left corner of instrument panel. It has two spade connector terminals out the back, is one simply ground and the other 12 volts? Does it matter which wire goes where?
Leo #1405213 04/08/2021 1:15 PM
Check the colour of the wires I see in some pics on line that there is a orange and a black.If you have a truck Manuel the wiring diagram may show it also ,are the connectors the same colour wire as the clock
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
Leo #1405216 04/08/2021 1:31 PM
Leo
Offline
Moderator
Moderator
Thanks Kevin but the clock back has just two spade connectors, just the male ends, no wires.(similar to the back of a flasher unit)
Leo #1405217 04/08/2021 1:33 PM
Was looking on line and found this if it helps
"The Journey"
Follow in the DITY
Leo #1405220 04/08/2021 1:36 PM
One more picture for fuse panel spot number 70.Check under dash there may be the plug hiding wrapped up under there .
"The Journey"
Follow in the DITY
Leo #1405223 04/08/2021 1:48 PM
Leo
Offline
Moderator
Moderator
Thanks Kevin.
