1 members (Samantha), 80 guests, and 1 robot.
Topics128,049
Posts1,055,637
My kid and I replaced a headlight switch on his '52 panel today. It was a replacement switch (12 volt) with the removable shaft. When the park lights were turned on, the headlights came on. Are only the park lights supposed to come on when the switch is in the first position? Are the park lights supposed to turn off when the switch is in the second position (headlights on)? All the lights work (i.e.brake, turn, hi-beam,low-beam). If I leave it the way it is, will it cause any problems? Thanks.
It's a small world, but I wouldn't want to paint it.
Insomniac
Insomniac
Quote
Yes
Quote
Yes
Quote
Probably OK. If the circuit breaker trips, you have too much load. I wired the parking lights to the tail light terminal so the parking lights are lit in both positions. No issue with that.
Gord 🇨🇦
1954 1/2 ton 235 4 speed
Figured it out. My kid had put the headlight wire on the taillight terminal.. He misread a diagram of the switch.
