0 members (), 40 guests, and 2 robots.
Topics128,030
Posts1,055,428
Members48,422
#1404812 04/05/2021 1:48 AM
just bought my 54 3100 with original gauges and none are hooked up. i see the previous owner installed a 12v starter and alternator. i was wondering is there a 12v to 6v transformer i could use to hook up the gauges with???
thanks
1954 Chevy 3100 with a straight 6cyl
moeman 59 #1404844 04/05/2021 12:09 PM
There is a Tech Tip discusses/describes the 6v to 12v conversion.
A special type pf 12v to 6v voltage reducer is needed for the furel gauge: it is call a "Runtz" style reducer.. IT MUST BE INSTALLED IN THE CORRECT DIRECTION/ORIENTATION.
Installation Instructions
More installation instructions from Randy Rundle.
moeman 59 #1404860 04/05/2021 2:15 PM
The only things needing attention in the gauge cluster on a 54 are the bulbs and the fuel gauge. The temp is mechanical, the oil pressure mechanical, and the amp gauge cant tell 6v amps from 12v amps. As suggested get a voltage reducer for the gas gauge and your home free.
Evan
moeman 59 #1404867 04/05/2021 3:53 PM
Moderator, Electrical Bay
Too bad the Vol-Ta-Drop is gone. That was far and away the best, the most trouble-free and longest lasting voltage dropper made. You could watch on eBay for one. I have one, but I've been using it without any trouble for over 45 years...new I think I paid $3 for it. Maybe I need to re-create those now that Columbia Radio quit making them?
~ Jon
moeman 59 #1404870 04/05/2021 4:28 PM
You can get a reducer from https://vintageautogarage.com
I have not bought from them but saved their 6-12 volt conversion booklet for future reference.
link to the booklet pdf
https://vintageautogarage.com/conte...al_RLS200322_no-TC_digital-converted.pdf
Best,
Michael
Jon G #1408480 05/03/2021 8:56 PM
JonG Question...on the light switches what do you recommend on aspray thru the knob hole to lube a switch that is just dry and kinda stiff ?? fixite
moeman 59 #1408636 05/04/2021 7:32 PM
543100chevy All you need is bulbs and a fuel gage volt reducer, however Ihave a 51 gage on 12 volt since 82 still Ok !!
