| | | Forums66 Topics128,030 Posts1,055,424 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2021 Posts: 28 'Bolter | | 'Bolter Joined: Apr 2021 Posts: 28 | just bought my 54 3100 with original gauges and none are hooked up. i see the previous owner installed a 12v starter and alternator. i was wondering is there a 12v to 6v transformer i could use to hook up the gauges with???
thanks
1954 Chevy 3100 with a straight 6cyl
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | The only things needing attention in the gauge cluster on a 54 are the bulbs and the fuel gauge. The temp is mechanical, the oil pressure mechanical, and the amp gauge cant tell 6v amps from 12v amps. As suggested get a voltage reducer for the gas gauge and your home free.
Evan
| | | | | Joined: Mar 2014 Posts: 4,479 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,479 | Too bad the Vol-Ta-Drop is gone. That was far and away the best, the most trouble-free and longest lasting voltage dropper made. You could watch on eBay for one. I have one, but I've been using it without any trouble for over 45 years...new I think I paid $3 for it. Maybe I need to re-create those now that Columbia Radio quit making them?
~ Jon 1952 1/2 ton with 1959 235 | T5 with 3.07 rear end
| | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | JonG Question...on the light switches what do you recommend on aspray thru the knob hole to lube a switch that is just dry and kinda stiff ?? fixite | | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | 543100chevy All you need is bulbs and a fuel gage volt reducer, however Ihave a 51 gage on 12 volt since 82 still Ok !! | | |
