| | | Forums66 Topics128,021 Posts1,055,346 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2019 Posts: 95 'Bolter | | 'Bolter Joined: Mar 2019 Posts: 95 | Getting ready to tear into one of my used 235 engines to asses it`s condition. I do not own a micrometer and need to shop for one that will work for pistons, crank etc. Planning on going non digital . Seeking input on what size mic I need and any other helpful hints. Also should I get a dial caliper or digital style for checking cylinder bore, Thanks all.
1953 3100 Pu
| | | | | Joined: Apr 2016 Posts: 1,036 'Bolter | | 'Bolter Joined: Apr 2016 Posts: 1,036 | You can do a lot with a set of micrometers and those little telescopic T things. The cheap digital slide calipers are extremely handy and pretty accurate. JMHO.
| | | | | Joined: Jan 2017 Posts: 62 'Bolter | | 'Bolter Joined: Jan 2017 Posts: 62 | I have a 0 to 6 set of offshore outside mics that i bought about 10 years ago, they were pretty cheap and have held up very well. I'm not a big fan of cheap digital calipers, my preference is a Starrett 6 inch dial caliper. Only digital caliper I've used that I really like is the Mitutoyo Absolute
| | | | | Joined: Feb 2000 Posts: 5,194 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,194 | Micrometers are nice, but expensive. I use a dial caliper for everything. You can buy a decent caliper for not much money, and if you drop it, it won't ruin your day! A dial caliper and set of snap gauges will let you measure every part of the engine. | | | | | Joined: Feb 2004 Posts: 29,746 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,746 | Dial calipers are for making somewhat educated guesses. They are far too susceptible to making huge mistakes from applying too much or too little pressure to the handwheel, or getting the jaws misaligned while taking measurements. Even an inexpensive set of 0-6 inch micrometers from Ebay is head and shoulders ahead of a good digital caliper. I've got both- - -a 6" Starrett digital for when I want to make a pretty accurate guess, and a set of micrometers with a Vernier scale for when I want to slice a strand of hair into several equal increments. I've also got a set of inside mikes, and at least half a dozen different types of dial indicators. I use them all, regularly, and trying to make one do the job of another is a lost cause. I'm accustomed to splitting thousandths when I'm boring and honing cylinders for new pistons, and working to the same accuracy when reconditioning conacring rods. The oil clearance on a 2" diameter solid steel wrist pin in the connecting rod bushing for an 855 cubic inch Cummins Diesel is .0004"- - - -that's a strand of hair split into three equal slices. Engine machining is no place for "Measure it with a micrometer- - - -mark it with chalk- - - -cut it with an axe!" Jerry
| | | | | Joined: Jan 2017 Posts: 62 'Bolter | | 'Bolter Joined: Jan 2017 Posts: 62 | " They are far too susceptible to making huge mistakes from applying too much or too little pressure to the handwheel, or getting the jaws misaligned while taking measurements."
Truth! Calipers are great for layout or a quick reference but measuring +-.005 is best done with a mic. | | | | | Joined: Aug 2001 Posts: 3,587 Moderator | | Moderator Joined: Aug 2001 Posts: 3,587 | Jerry, you forgot that the thickness of a hair depends on the the natural hair color. Redhead, blond, brunette and black. Also the part of the body it came from!  Dial or digital calipers are not to be trusted to measure any less that +/- .005. Even mics can not be right, if used by someone that does not know how to use one. Don 1967 GMC 9500 Fire Ladder Truck"The Flag Pole"In the Stovebolt Gallery1946 2-Ton grain truck 1946 3/4-ton pickup, 1953 1-ton pickup 1957 1-ton flatbed dually, 1954 Pontiac Straight Eight Of all the things I've lost in my life, I miss my mind the most! | | | | | Joined: Feb 2004 Posts: 29,746 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,746 | Don, are you gonna burst my bubble and tell me that a mike can't be used as a C-clamp on a welding project????????  Jerry
| | | | | Joined: Feb 2000 Posts: 5,194 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,194 | Dial calipers will let you someone new to measuring find out the condition of the engine, If it needs work, the machinist will do the measuring when it comes time. You sure don't need to measure in ten thousandths to know if the engine is going to the shop or not.
Dial calipers can be zeroed out anytime they need to be checked, try that with a set micrometers when you don't have calibrated gauge blocks, and quality calipers will measure down to the .001" if you take to time to learn how to use them.
I was a machinist for 11 years working in the aerospace industry, I ran all types of lathes with all types of material. Ever machine a magnesium nose cone 14" across with tolerances +.00001 to -.00005 on a manual 50 year old lathe, I have. | | |
