| | | Forums66 Topics128,050 Posts1,055,639 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2021 Posts: 24 'Bolter | | 'Bolter Joined: Jan 2021 Posts: 24 | I replaced the master cyliner, all 4 wheel cylinders, and the 2 front rubber brake lines. The brake pedal will go to the floor when I first push it but will build pressure if i pump the brake a few times. I have tried bleeding the brakes a few times without luck and i am not losing brake fluid anywhere. I have never bled brake lines before, am i doing it wrong or is there something else? Thanks Steve
1949 chevy 3600 First attempt at restoration
| | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | To help we need to know every time you start a new thread exactly what truck you are working on. What procedure are you using to bleed the brakes? Yes there is a “Right” way to do it. We will walk you through it once we know what you are working on.
| | | | | Joined: May 2015 Posts: 11,027 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,027 | Steve, I reviewed your other thread about the drums binding up, and you said that you had to file off the wheel cylinders to get the drums freed up. Is it possible that you put the cylinders on upside down? That would cause a problem with bleeding as the bleeder screws wouldn't be at the top of the cylinder. Just a thought.
What Martin said about telling us what you're working on. If you only have one truck, put that info in your signature in your profile (click your username in the upper right and chose "edit profile" then scroll down that page till you get to signature and put the info there.) It will appear in all your posts.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Jan 2021 Posts: 24 'Bolter | | 'Bolter Joined: Jan 2021 Posts: 24 | Thanks for the feedback. I have a 1949 Chevy 3600. The bleed screw is on the top. Our technique has been my wife pumping the brake pedal several times and then holding pressure while I open the bleed screw for a few seconds. I am not seeing any air bubbles. I bled in the order listed in the manual - driver side rear, driver front, passenger rear, passenger front. I have read other posts saying to do the rear wheels first, but decided to follow the manual. I appreciate any input.
| | | | | Joined: Mar 2019 Posts: 119 'Bolter | | 'Bolter Joined: Mar 2019 Posts: 119 | I assume that you adjusted the brakes as described in the '49 shop manual before trying to bleed the system. If there is too much clearance between the shoes and drum the pistons will move to the end of their travel without any air or fluid coming out the bleeder.
Rusty
| | | | | Joined: Jan 2021 Posts: 24 'Bolter | | 'Bolter Joined: Jan 2021 Posts: 24 | I did adjust them prior to bleeding them. I do get brake fluif out when I bleed them
| | | | | Joined: Feb 2004 Posts: 29,766 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,766 | Once you get some pedal after a few pumps, does it feel firm, or is the pedal "spongy"? If there is air trapped somewhere in the system, it will compress as pressure is applied, giving the brake pedal an uncertain feel and poor braking of the vehicle. If the shoes are simply out of adjustment, after pumping the pedal enough to displace fluid and get the shoes firmly against the drums, the pedal will feel solid. The fix for these two problems is different. Try adjusting the brake shoes until it's difficult to turn the wheels- - - -not locked up, but enough that it takes some effort to turn each wheel. Then try the pedal. If it's firm, with little if any travel, you've found the problem. If the pedal still requires a few pumps to keep from going to the floor, there's still some air trapped somewhere. Jerry
| | | | | Joined: Jan 2021 Posts: 24 'Bolter | | 'Bolter Joined: Jan 2021 Posts: 24 | It is the second - firm not spongy. I will try adjusting the shoes. Thank you.
| | | | | Joined: Feb 2004 Posts: 29,766 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,766 | Adjusting Huck brakes can be a frustrating chore. Each shoe has its own adjustment, so you're going to repeat the process 8 times before you're done. I believe the procedure is to tighten the shoe firmly against the drum, and then back off until the wheel turns freely, but don't overdo it. A low or no pedal situation when there's not any air in the system means that the full stroke of the master cylinder is being used up just to get the shoes into contact with the drums. As long as even one shoe has room to move, none of the otherws will apply any force to the drums. The closer you can get the shoes toi the drums without creating a constant drag situation, the more pedal height you'll have. It's a constant balancing act between pedal travel and not making the brakes drag. Huck brakes also have to "wear-in" until there's full contact between the linings and the drums, so you might have to do repeated adjustments after getting the brakes relined. Jerry
