6 members (Gdads51, tclederman, sron48, FAST55, Hambone, cmayna), 149 guests, and 1 robot.
Topics128,111
Posts1,056,258
Members48,437
#1404515 04/03/2021 3:24 AM
Any of you folks used POR-15 paint on wheels? Mine are pitted on my big bolt. I have wire wheeled them but will they need something under the por , primer or rust converter?
1950 4400
Insomniac
Insomniac
Sandblast and prime with epoxy primer should work. No POR-15 required.
Gord 🇨🇦
1954 1/2 ton 235 4 speed
Fox Offline
Go with Gord’s suggestion. Epoxy. Por15 is uv sensitive and will fade from the sun. Also, POR15 won’t stick to a wire wheeled surface. It will peel off in sheets. Ask me how I know. It needs a rough surface to bite into. If you sandblasted and then POR’d it, it would probably work, but I’d use epoxy from now on.
1970 Chevrolet C10
1950 Chevrolet 1-Ton Dually
"Ole Red Girl"
More pictures here
Parts trucks-
back yard wrench turner
Use Master Series silver on the wheels. It will adhere, fill the pits and harder than 2K epoxy.
http://masterseriesct.com/
Wayne
1938 1-Ton Farm Truck
Stovebolt Gallery Forums
1989 Silverado
1996 Mustang GT convertible
THE BEST STUFF ON THE MARKET!
Its kinda like the hot sauce commercial.... “I put that sh** on everything” 👍
Joe Alan #1404544 04/03/2021 12:50 PM
24601
Of course it's good -- the company is run by a VW lover from Connecticut. People don't come better than that.
smile
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
I had some rust bubbling after about 13 years of use. I did sandblast, epoxy, paint.
Thanks for the help!
1950 4400
Never heard of it, but sounds good I might try it, thanks
1950 4400
