9 members (Wayne67vert, TooMany2count, Nick in Manitou, NJC, Mike in Sycamore, Bill Hanlon, Ponchogl, sron48, rfs56trk),
85
Mod | | | Forums66 Topics128,137 Posts1,056,747 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2019 Posts: 32 'Bolter | | 'Bolter Joined: Jul 2019 Posts: 32 | I've done a fair amount of searching on the internet but have come up with shallow, somewhat confusing info. I'm trying to get solid ID and the year range for my 5-speed manual trans so I can get the right parts for it. It is bolted up to the back of my Chevy V-6 4.3 (which is another thing I need to clarify the ID of...)
I picked it thinking it was an NV3500 but now suspect it might be one of the older versions. The tag reads:
DXF 12572824 MUNCIE *61 DXF M040034
Thanks! | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Picture would help. Al or Ci?
Ed
| | | | | Joined: Jul 2019 Posts: 32 'Bolter | | 'Bolter Joined: Jul 2019 Posts: 32 | Picture would help. Al or Ci?
Ed Will grab some and post shortly. Aluminum. | | | | | Joined: Jul 2019 Posts: 32 'Bolter | | 'Bolter Joined: Jul 2019 Posts: 32 |
| | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | I would think the DXF would mean something to a dealer, or even parts supplier.
Ed
| | | | | Joined: Mar 2006 Posts: 319 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 319 | An internet search for "GM 12572824" shows that this was installed in 120 different vehicles from 1999-2007. It was mated to 4.3 and 4.8L vehicles. I agree that understanding the DXF designation would narrow the application. I don't have that info. Good luck on your search.
"Nothing astonishes men so much as common sense and plain dealing." - Ralph Waldo Emerson
| | | | | Joined: Mar 2006 Posts: 319 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 319 | One more piece to your puzzle. This entry from this online parts service shows a transmission with your part number and the DXF designation being for use with the 4.3 L engine and used in a 2007 year. You'll know more after you chat to a good parts dealer. Again good luck. https://www.wholesalegmpartsonline....assembly=372049&ukey_product=2667325
| | | | | Joined: Jul 2019 Posts: 32 'Bolter | | 'Bolter Joined: Jul 2019 Posts: 32 | The links are huge. Thanks all very much! | | | | | Joined: Jan 2011 Posts: 2 Moderated | | Moderated Joined: Jan 2011 Posts: 2 | 12572824 dxf is a 2003 chev 1/2 ton 4x2...NV3500......also fits other years.. retired New venture distributer..i hung on to all bill of material info.. | | |
