5 members (46 Texaco, Hotrod Lincoln, 3 invisible), 90 guests, and 1 robot.
Topics128,115
Posts1,056,633
Members48,450
When I take something apart, I use a piece of cardboard to help remember where everything went. For example, when removing the cylinder head, sketch the shape of a cylinder head on a piece of cardboard, punch holes in the cardboard with a phillips screwdriver approximately where the bolts are. Label the drawing front, head, valve cover etc. As I remove the bolts, I stick them into the cardboard. This helps me to remember what the bolts were for and where they went. The picture shows the six spark plugs I just took out and keeps them in order by cylinder, and another piece of cardboard with fasteners from a riding mower that is waiting for parts
James S
Interesting. I use a similar method to paint my bolt heads.
Another quality post.
Real Trucks Rattle
I have used this technique for years. It has saved me many times.
Whenever I start working on a car with a person who is just starting out in this hobby I make them use this technique. I get some push back. They are pretty quiet when we start putting things back together in 3 or 4 weeks. What they thought was obvious when we took it apart is no longer obvious.
The funniest story about this technique happened when 2 people I had worked with met each other for the first time. They determined that they both knew me. They immediately asked each other if I made them use the cardboard fastener holder.
Rusty
AD Addict & Tinkerer
My Dad taught me that trick for keeping push rods in order 50 years ago. I also use it like Rusty Rod for painting bolt heads!
Phil
Project Journals
Stovebolt Gallery Forum
