| | | Forums66 Topics128,195 Posts1,057,370 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2007 Posts: 39 'Bolter | | 'Bolter Joined: Jun 2007 Posts: 39 | anybody know where i can purchase single stage touch up paint in small bottles | | | | | Joined: Jul 2019 Posts: 559 'Bolter | | 'Bolter Joined: Jul 2019 Posts: 559 | Local auto paint shop. Should be able to either match a color or go off a good number. They can put it in a spray can, quart, or smaller. | | | | | Joined: Sep 2010 Posts: 2,337 'Bolter | | 'Bolter Joined: Sep 2010 Posts: 2,337 | Best to bring a small piece of painted body to the paint shop (bracket or something maybe they can test colour from the truck if you bring it down).Some paint colours have about 10 variants so if you give them a paint code they can be off by a little . Found that out after I had the paint shop make up a spray can only to find out about the variants in the code for the colour. | | | | | Joined: Jun 2006 Posts: 693 'Bolter | | 'Bolter Joined: Jun 2006 Posts: 693 | try this place. I have ordered from them successfully several times. you do have to enter that you want Single Stage (SS): www.paintscratch.com | | | | | Joined: May 2006 Posts: 934 'Bolter | | 'Bolter Joined: May 2006 Posts: 934 | I will second the recommendation for the above company. I have had good results ordering from them and matching paints. Recently I received a couple spray cans of paint from them and the color match was impeccable. | | |
