| | | Forums66 Topics128,163 Posts1,057,044 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2018 Posts: 27 'Bolter | | 'Bolter Joined: Oct 2018 Posts: 27 | Hi all, I had new glass cut for my cabin but unfortunately the stainless edge trim that runs on the stationary pieces was epoxied to the old glass and looks to be inseparable or at least unusable(damaged by process) if I were to work that bond apart (open to suggestions)...
Wondering if anyone has sourced any pieces in aftermarket boating or otherwise to at least mimic these pieces. I have a few ideas but didn't want to order anything till I polled the informed crowd here.
Thanks!
| | | | | Joined: Oct 2005 Posts: 4,260 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,260 | Swizcore, what exactly are you working on? GM started making the Suburban in 1935 and is still making them today. You'll have to narrow it down a little. | | | | | Joined: Dec 2002 Posts: 3,445 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,445 | I googled this
how do you dissolve epoxy glue
and came up with a few products. Goof off is usually pretty good. I'd definitely read the label first if there is something adjacent to the trim you are trying to save that you do not want damaged.
| | | | | Joined: Oct 2018 Posts: 27 'Bolter | | 'Bolter Joined: Oct 2018 Posts: 27 | Swizcore, what exactly are you working on? GM started making the Suburban in 1935 and is still making them today. You'll have to narrow it down a little. Oops, itβs a 55 1st series. | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Mirror channel. Shower channel. Car door edging. All kinds of chrome glass edging available. Stainless or chrome J channel or U channel.
I prefer solid side glass, no sliders.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | I like (and, my passengers like) the sliding side windows on my 1954 Suburban (A-D, Advance-Design series).
Nothing rattles and nothing leaks. I used new "seals".
However, I wish I had cleared the drain-holes/drain-tubes in the body below each side window. | | | | | Joined: Jun 2001 Posts: 793 Bondo Artiste | | Bondo Artiste Joined: Jun 2001 Posts: 793 | Nothing better than the original slider windows in these old burbs. One piece windows, no thanks, unless you want a oven inside your Burb during the summer.
~ Phillip 1949 GMC Suburban - 10 year project 1952 Pontiac Chieftain Convertible straight 8 hydramatic 1945 GMC half ton truck - Driver- Sold 9-15-25 1946 Chevy COE - SOLD 1-5-26 BUH BYE CHEVY! 1959 GMC Half ton long bed NAPCO | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Mirror channel. Shower channel. Car door edging. All kinds of chrome glass edging available. Stainless or chrome J channel or U channel.
I prefer solid side glass, no sliders. I apologize for the distraction. You just asked for trim.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Oct 2005 Posts: 4,260 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,260 | Back on track folks! Let's help Swizcore either break the epoxy bond between his old glass and stainless pieces, or find a reasonable replacement. I vote for finding a way to save the originals.
I would caveman the glass out of there and carefully scrape the rest out. | | | | | Joined: May 2015 Posts: 11,152 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,152 | Epoxy will let go with a little heat. It's only good up to about 300F. Bake it in the oven or gingerly use a propane torch. If the trim is painted, you'll probalby have to redo that, but chrome or stainless should stand the heat if you don't overheat.
Are you sure it's epoxy? Glass setting tape (rubberized stuff that's surely turned to a rock over the years) can be loosened by soaking it with solvent. The service manual says gasoline!!
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Lay trim on carpet and ship out glass and bonding material as said by MNSmith. Doubt if it is epoxy, lots of material turns to rock as Kevin said. Try not to dent the SS. But It can be straightened and polished.
Going caveman steps: 1. Gently tap glass and bonding out, in you nice clothes. 2. Hit it a little harder 3. Bigger hammer 4. Try a solvent wearing safety glasses. Change to your old levis and shirt. 5. Try gasoline to loosen it. 6. Change to just shorts and a wife beater shirt. 7. Light the gasoline on fire. 8. Swing it with a chain attached, while on fire, against a block wall. 9. Torch it with oxy torch while on fire. 10. Stop for a raw meat lunch eaten with hands and drink ale from a wooden jug. 11. Sleep outside overnight. On the ground. 12. Next morning: Order some chrome mirror edging or something like that. 13. Clean up your mess. Shave and comb your hair.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Oct 2018 Posts: 27 'Bolter | | 'Bolter Joined: Oct 2018 Posts: 27 | I like and appreciate all these suggestions. I'm on vacation till Tuesday but when I return I will give it my best effort to re-use the originals. Plenty of methods to try thanks to you guys. My glass guy said it was epoxy and upon first look to me I'd say it is indeed either epoxy or possibly 3M Yellow Super Weatherstrip Adhesive. In my experience I can be more stubborn than many of these jigsaw puzzles I come up against.. I'm optimistic and will report back.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Oct 2005 Posts: 4,260 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,260 | LOL, bartamos! Can we skip to step #10? | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | It seems you may have to buy a case of 25 96" long pieces.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Oct 2018 Posts: 27 'Bolter | | 'Bolter Joined: Oct 2018 Posts: 27 | I contacted them and they do sell individual 96β sticks for $84 each plus a $30 shipping fee(to Michigan in my case) but I found a supplier online that gets a 96β stick to me for just shy of $80 delivered. | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | That info will be very useful to others on Stovebolt now and in the future. Very good follow up Swizcore.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Oct 2018 Posts: 27 'Bolter | | 'Bolter Joined: Oct 2018 Posts: 27 | Just to be as comprehensive as possible, here is the link to the product page I mentioned before in my pricing description. https://www.defender.com/product.jsp?id=4483343 | | |
