0 members (),
166
Mod | | | Forums66 Topics128,196 Posts1,057,386 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2020 Posts: 71 'Bolter | | 'Bolter Joined: Jan 2020 Posts: 71 | I'm so close to finishing this rewire job up I can taste it, however, I've found a few problems.
1) Question, I put LEDs in my dash, is that a problem? They light up but aren't near as bright as I was expecting them to be 2) Put in a new turn signal switch, the turn signal comes on but it doesn't flash on and off, these are LEDs also, this could be the problem why they aren't flashing, just haven't checked that yet 3) Added a cigarette lighter, just trying to figure out where to get the power for it, I'm guessing that I should fuse it also 4) My license plate light isn't working, but I'm guessing that's a minor issue
Sure hope to be on the road soon, I've just hit and missed on this rewire and took my time, but I can see the light at the end of the tunnel
"The greatest use of life is to spend it on something that will outlast it" ~ William James
'25 Chevy Superior '66 Chevy C10 '03 Chevy Silverado 1500 HD
| | | | | Joined: Mar 2020 Posts: 197 'Bolter | | 'Bolter Joined: Mar 2020 Posts: 197 | LED's shouldn't be a problem just remember they are polarity sensitive. I'm assuming the system is 12v correct? Turn signal not flashing could be a few things, a common one is that some kits don't come with a flasher unit, if the system is wired without one you will have solid lights. I would fuse the lighter but the one in my truck is not fused and that looks factory. For the license plate light I would check grounds first.
62' GMC Fleetside 3/4 ton 235 4-speed. Time makes fools of us all.
| | | | | Joined: Apr 2005 Posts: 7,441 Bolter | | Bolter Joined: Apr 2005 Posts: 7,441 | I seem to recall past discussions on LEDs requiring a special flasher.
| | | | | Joined: Sep 2011 Posts: 1,462 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 1,462 | LED lamps do not flow enough current to activate older flashers.
BC 1960 Chevy C10 driver 261 T5 4.10 dana 44 power loc 1949 GMC 250 project in waiting 1960 C60 pasture art Retired GM dealer tech. 1980 - 2022 | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | 6v LED flashers are readily available
2-prong and 3-prong flashers - positive ground (GMC) or negative ground (Chevrolet).
If interested, do an Internet search. | | | | | Joined: Jan 2020 Posts: 71 'Bolter | | 'Bolter Joined: Jan 2020 Posts: 71 | Thanks for the input guys. My system is 12v. I did buy a more powerful flasher can, but it didn't seem to fix the problem. Do I have to have one in both the Turn Signal flasher and the hazard flasher? The hazard flasher still has the normal can in it.
