6 members (Uncles51, Peggy M, dwreills, JW51, Millenimech, Chip O), 41 guests, and 1 robot.
Topics128,035
Posts1,055,446
Members48,422
#1403318 03/27/2021 9:10 PM
I installed a new vacuum advance on my 54 235 truck engine .Prior to removing dist, made reference marks as to position of rotor,postion of dist itself, and postion of dist body when i removed the old vacuum advance. The problem that I have is installing the dist. It will drop down so far,but not flush with the block. The rotor feels tight and lines up pretty close as to where it was when removed. Did I do something wrong,or maybe the wrong vacuum advance? Any and all advise is welcome. Thank you
wilbur53 #1403398 03/28/2021 11:56 AM
You need to use a long flat blade screwdriver to line the oil pump up.
wilbur53 #1403401 03/28/2021 12:13 PM
AD Addict & Tinkerer
As you drop the distributor, the oil pump tang (and rotor) will turn as the distributor drive gear meshes with the cam shaft gear. You will have to turn the rotor slightly to compensate or the tang will not engage in the oil pump, preventing it from dropping fully.
What I do, in addition to marking the distributor as you did, is to place one additional mark (rotor to distributor) as your pulling out the distributor, just after the drive gear clears the cam gear, so you know where to set the rotor (how much compensation) so tang engages the oil pump.
Phil
Project Journals
Stovebolt Gallery Forum
wilbur53 #1403515 03/28/2021 10:13 PM
Thank you for the replies. Got it installed and as luck would have it-----was able to start engine on first try.
