4 members (Hanks custodian, Gdads51, Bill Hanlon, Nick in Manitou), 173 guests, and 2 robots.
Topics128,197
Posts1,057,258
Members48,466
My 1957 Panel's driver-side, upper door hinge, is missing the top bolt. I can't tell from looking, through the hole, if the cage nut is in there or not.
If I remove the hinge from its location, would I be able to feel up inside to determine if the nut is totally gone or not? I can't see down from the top obviously, as there is the cowl/metal there.
Thanks in advance!
1957 Chevy Panel Truck, powered by SBC 350 from 1977 Camaro
Author, Bring CHANGE Into Your Life (a truly easy investment tool)
https://www.amazon.com/Bring-CHANGE-Into-truly-investment/dp/1077276869
Sir Searchalot
Sir Searchalot
I believe that one is accessible from outside of firewall. May have to take off fender.
Thanks for the response- I'm pretty sure it is covered, but will check again.
EDIT: you're right!!! I just checked one of my pics and I can see it!! Thank God for hi res pics!!
I've ordered the missing bolt from H and H Classic Parts in AR. This is my first order with them, and it looks like the bolt should be here tomorrow. Man I hope so, I really need to get that driver door on!!
So the parts came, and when I checked the hinge, I learned that THREE bolts hold it in place, not 2. The worst part is, I need the backing nut/block nut/whatever you call it for the UPPER hole (shown in pic). Where can I buy or order those? I don't have the means to machine one myself.
After reading up, the cage nuts are available through Mar K. That supplier is a bit pricey for me, but I went ahead and ordered some.
