2 members (MNSmith, Phak1),
120
Mod | | | Forums66 Topics128,284 Posts1,058,528 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#14031 05/17/2005 8:17 PM | Joined: Feb 2005 Posts: 81 Member | | Member Joined: Feb 2005 Posts: 81 | over the weekend i finally got to replacing a leaking wheel cylinder and a questionable master cylinder on my '52 3/4 ton chevy. i've been pondering making my own adapter brackets to mount disk brakes on the front and having gotten a really good look at what kind of space there is and how things mount i don't believe the bracket and caliper clearance will be difficult at all. my questions for the stovebolters are these: 8 lug rotors are easy enough to find, are there different "offsets" which i'm calling the height of the mounting surface to the braking surface? if so is there a certain one that is more common? how about diameters? putting disks on the front means a new master cylinder again. will the brackets that adapt a dual circuit chevy M/C to a 1/2 ton truck that classic performance offers work on the 3/4 ton? i'd like to avoid the firewall mount systems, the firewall is one of the few straight pieces of metal on my truck what about tapered roller bearings for a 3/4 ton, even if i don't pull off the disk swap? anyone have more insight to things i'm missing? thanks | | |
#14032 05/18/2005 4:49 PM | Joined: Mar 2004 Posts: 874 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 874 | Not sure about the different offsets on rotors, but I've heard of a couple guys using around 1990 or so 8 lug 4wd rotors for this. I was contemplating this retrofit myself on my 52 3/4 ton but ended up getting a 1/2 ton front axle and a 6 lug disc brake kit. Also got a 1955 1/2 ton rear axle. (to match the 6 lug front hubs) The spring perches on the 55 axle have the same spacing as the original rear, so no cutting and welding is required. | | |
#14033 05/18/2005 5:12 PM | Joined: Feb 2005 Posts: 81 Member | | Member Joined: Feb 2005 Posts: 81 | i considered going after 1/2 ton axles, but i want to preserve the load capability of the truck. that bigass axle in the back looks cool to boot good to know about the spring perch spacing though. thaks | | |
#14034 05/19/2005 12:21 AM | Joined: Feb 2003 Posts: 452 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 452 | The dual MC from a modern 3/4T should bolt to the 1/2T brackets. From what I've seen in junk yards, the MC mount to the servo is pretty standard. I saw a ford 3/4 or 1T in the yard with slide-off disks, rather than bolted to the hub. It also had a bolt-on caliper carrier. I never got the chance to see if the pattern was even close to the backing plate on my 49, but wouldn't that be a dream com true (not ford, bolt-on disks for a 3/4T). If you find a good method, let the rest of us know!
Current fleet (subject to change w/o notice) \'49 GMC 3/4-Ton , 60 Austin Healey Frog-eye Sprite (some assembly required), 2011 Dodge Avenger, 2015 Jeep Cherokee. No, they don't all run. My other ride is a (B737)no, (B767)no, A320.... Update... was Embraer E190, now Boeing B787. Knowledge is a wonderful thing, but ignorance means you don't know you can't do something.
#14035 05/19/2005 12:26 AM | Joined: Feb 2005 Posts: 81 Member | | Member Joined: Feb 2005 Posts: 81 | highflyer, i'm planning to make brackets. i'm lazy, and going to the boneyard looking for recycled brackets is way harder than a little quality time with the new mill here at work i'll definitely keep y'all posted if i get to it.... be prepared to wait though :rolleyes: | | |
#14036 05/19/2005 6:54 AM | Joined: Feb 2003 Posts: 452 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 452 | If you can mass-produce, I might be interested. I would also like to go with disks, but don't have the manufacturing skill or equipment (I'm a bolt-on kinda guy). Did you see the website of the guy who put disks on the 3/4T burb? there should be a thread here somewhere with his website.
#14037 05/19/2005 5:48 PM | Joined: Nov 2001 Posts: 481 Shop Shark | | Shop Shark Joined: Nov 2001 Posts: 481 | I'm also interested in disc brakes for the 3/4 ton. Let us know what you figure out please . | | |
#14038 05/20/2005 10:03 PM | Joined: Feb 2005 Posts: 81 Member | | Member Joined: Feb 2005 Posts: 81 | i haven't seen the 3/4 ton burb setup.... gonna go search
producing them for use by others has liability ramifications but maybe. | | |
#14039 05/21/2005 1:52 AM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | The guy who did the conversion no longer has his website up. I tried e-mailing him while it was still up, but he never responded. I cannot recommend following his instructions, he made the brackets from cold-rolled plate.
Fred 52 3600 69 C-10
#14040 05/21/2005 3:05 AM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | One of my brothers has recently invested in a garage full of machine tools to set up his own shop.
I've been talking to him about creating a disk brake conversion for 1-ton and 3/4-ton Stovebolts.
The liability issue has stopped me cold. I don't think designing a conversion would be a big problem, but between the size of the market (I'm sure we could sell six or eight of them) and the liability exposure I think I now know why there isn't a kit available for the bigger trucks.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
#14041 05/23/2005 9:38 PM | Joined: Feb 2005 Posts: 81 Member | | Member Joined: Feb 2005 Posts: 81 | Originally posted by Fred T: The guy who did the conversion no longer has his website up. I tried e-mailing him while it was still up, but he never responded. I cannot recommend following his instructions, he made the brackets from cold-rolled plate. what would you use and why? IIRC cold rolled has better grain structure than hot rolled | | |
#14042 05/23/2005 9:44 PM | Joined: Feb 2005 Posts: 81 Member | | Member Joined: Feb 2005 Posts: 81 | Originally posted by OldSub: One of my brothers has recently invested in a garage full of machine tools to set up his own shop.
The liability issue has stopped me cold. I don't think designing a conversion would be a big problem, but between the size of the market (I'm sure we could sell six or eight of them) and the liability exposure I think I now know why there isn't a kit available for the bigger trucks. yeah.... i'd consider making a drawing of whatever bracket i come up with available to someone to post but parts retailing.... darn lawyers another of my automotive addictions involves a small german car with 4 rings on the grill.... there is an organization out there that had to deal with the same issue in order to make brake bracket adapters available. they ended up having a non proffit organization set up, and by joining you forfeited all right to sue those that provided the info to make the brackets, or whomever you bought them off of. if i actually pull this off, i'll look into piggybacking on that. | | |
