| | | Forums66 Topics128,080 Posts1,055,953 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2020 Posts: 26 1952 Chevy Truck | | 1952 Chevy Truck Joined: Apr 2020 Posts: 26 | Just for fun, my truck started pulling hard to the right when I brake. One day last week it pulled left. Now it pulls right again. The master cylinder was changed last year and I bled the brake lines at that time. I'm looking for your suggestions on what might be causing my issue so I can try to tackle it this weekend. (No sign of leaking brake fluid of a broken line.)
1952 Chevy 3100 with GM Straight 6 250 engine
| | | | | Joined: Feb 2004 Posts: 29,780 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,780 | Change the flex lines from the frame to the front wheels. They fail from the inside out (collapse), and restrict the fluid flow to the wheel cylinders. Jerry
| | | | | Joined: Jul 2019 Posts: 559 'Bolter | | 'Bolter Joined: Jul 2019 Posts: 559 | Something loose in front end? Axle moving around or something odd like that? | | | | | Joined: Oct 2005 Posts: 4,252 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,252 | Could be a small slave leak, soaking the shoes without reaching the outside of the drums yet. A sure sign would be a slightly lower master level.
I would start with a visual on all four corners and master fluid level. Check lines, look at backing plates, etc. Look for small puddles under the vehicle. Eyeball the tires while you're at it. Look for separating tires, low air, etc. Eyeball your suspension while you're at it. If everything looks good, adjust your brakes and go for a test drive. If it still pulls, break out the jack and jack stands and start pulling drums. Start with the front axle as that is the usual area. Issues with the rear brakes can cause pulling, so pull those drums next. Keep looking until you find the issue, then repair it. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Most of the time it is caused by fluid or grease getting on the linings. Like Smith says, it may not be enough to leak out on the wheel or backing plate. Pull the front drums off & see what you got. File or sand a bevel on the edge of the linings. The reliners used to do this on new linings all the time but they don't put much attention to drum brakes anymore. The sharp edge can cause inconsistant braking. George They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Apr 2020 Posts: 26 1952 Chevy Truck | | 1952 Chevy Truck Joined: Apr 2020 Posts: 26 | Thank you all for the suggestions.
| | | | | Joined: Apr 2008 Posts: 899 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 899 | Oddly enough my 49 3100 started pulling left a couple days ago. Now I have some good starting points to work with! Thanks X2
Ed
| | | | | Joined: Apr 2008 Posts: 899 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 899 | Any thoughts on Dot 5 fluid? That's what I used years ago when I rebuilt the entire system on my 49 3100.
Ed
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I have had DOT-5 Silicone brake fluid in my 1954 3106 Suburban for about 20 years. In new stainless steel brake lines. No problems.
One you go to DOT-5 you cannot easily changed to a lower DOT-number brake fluid.
I do not think that I will use it in the 1954 3104 that I am restoring. | | | | | Joined: Jul 2000 Posts: 2,192 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,192 | Any thoughts on Dot 5 fluid? That's what I used years ago when I rebuilt the entire system on my 49 3100. Good stuff. I was thinking how good it was a couple of days ago. I was topping up the master cyl and I spilled some on the floor. It didn't mess up the paint like DOT 3 would.
Gord 🇨🇦 ---- 1954 1/2 ton 235 4 speed | | |
