1 members (Hotrod Lincoln),
72
0
Mod | | | Forums66 Topics128,049 Posts1,055,680 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2003 Posts: 1,061 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,061 | My 52 1 Ton (or it may be a chopped down, re registered 1.5 Ton based on some oddities), has pedal issues. It has been sitting for a long time so the front cylinders that I replaced were clogged up and I replaced the rear cylinders recently. The rears were the larger cylinders that used the round discs with the knobs. One of which i replaced so I could adjust the brake. I have also rebuilt the master cylinder. We used a brake bleeding device that used compressed air to force brake fluid through the master cylinder through the lines to the cylinders. The brakes have been adjusted out to the point of a slight drag on all the wheels.
The problem is, to get a decent pedal I still have to pump the pedal, typically a sign of air in the lines. I have not found any evidence of leakage at any point in the system, and with the solid stream of fluid coming out of the bleeders, I don't think I have air in the lines. Is there something in the master cylinder that could cause this or not enough adjustment on the drag?
Anyone with any thoughts?
1946 1-ton Panel 1952 1-ton Comml. W/Grain Body | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | You need to adjust the brakes up till you get a heavy drag. Then back them up a little till they turn without a heavy drag. You will still have some drag but they will free up as the shoes were into the drums. George They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Mar 2014 Posts: 154 'Bolter | | 'Bolter Joined: Mar 2014 Posts: 154 | Another thing that it took me a couple years to figure out with Huck brakes is you have to adjust both shoes separately, unlike Bendix brakes. Run one shoe out until it drags, then back it off and do the other side the same way. I used to have to pump my brakes also, with a good strong pedal after pumping. It just took too much fluid movement to get the shoes in contact with the drums, requiring the extra pump.
Greg Brown
| | | | | Joined: Jul 2019 Posts: 559 'Bolter | | 'Bolter Joined: Jul 2019 Posts: 559 | Yup as soon as mine wear a bit and get out of adjustment the pedal is noticeably lower but i dont let it get to the point where i need to pump it. I did however the first time around when i built it with the dual master and it was confusing at first but once I finally got the adjustment dialed in i was “ahhhh this is how its supposed to be”. Pedal went from 1.5” off floor to like only 1.5” total movement. Stopped great too haha. Now i just keep up on it.
| | | | | Joined: Dec 2003 Posts: 1,061 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,061 | Thanks for all the comments. Another thing I had forgotten about is that a rear backing plate is bent, due to pulling off the brake drum efforts. If it bent one way it will bend the other and then I can get back to the adjusting process.
1946 1-ton Panel 1952 1-ton Comml. W/Grain Body | | | | | Joined: Nov 1995 Posts: 5,716 62401 | | 62401 Joined: Nov 1995 Posts: 5,716 | Just another thought on the bleeding process using the power bleeder ... Did you stop bleeding once you got a steady stream? On my 1-ton Hucks, I found that after the initial steady stream, I would get another few air bubbles after a few seconds of the steady stream. I mention this just in case you didn't know to keep bleeding for awhile after you hit the steady stream. And yes, you will go through a lot of brake fluid. But I have rock firm brakes as soon as my foot touches the pedal. Everytime. I took my truck out Sunday for the first time since last fall (for a real drive) and the brakes were right there.
Follow all the advice above for adjusting. But I wonder if you are not yet done bleeding ... ?
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Jul 2019 Posts: 559 'Bolter | | 'Bolter Joined: Jul 2019 Posts: 559 | Make sure the master is returning ALL the way or it will not let it get fluid from the master how it should. | | | | | Joined: Dec 2003 Posts: 1,061 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,061 | Thanks John and Barnfind, I am going to resume this journey again this week. The master cylinder is the only thing that has not been replaced, only honed and rebuilt. This problem does not have just one cause in all likelihood.
