4 members (gswbbc, rfs56trk, HandyAndy, 1 invisible), 45 guests, and 3 robots.
Topics128,040
Posts1,055,478
Members48,424
#1402541 03/22/2021 6:50 PM
Hey all, I just picked up a 51' GMC 250 dumptruck that has an inline 6 with a chevrolet valvecover on it. I've tried looking up the number on the engine located by the dizy. F0222LB....if somene could please send a link to the engine #decifer information that would be super helpful.
53&Me #1402550 03/22/2021 7:54 PM
My guess would be 1953 3100 216 engine.
Find and post the following:
- block casting code
- block date casting code
- head casting code
- head date casting code
- the complete Engine Serial Number
53&Me #1402561 03/22/2021 10:10 PM
That looks like the later style engine number that started in '57 and ran through '62. If that's right, the F indicates Flint, MI manufacturing plant. 02 is the month - February. 22 is the day of the month. And LB is the service code.
LB was first used in '57, but for the 265 V8 - not correct. In '58, Chevy changed the service codes. L indicated 6000 series truck, and inline 261 engine. No LB code. In '59, L still indicates 6000 series truck with 261, but jumps to LC (no LB code), also a 261. Then in '60, the LB code shows up again, for 60-series trucks as the base engine, which would be the 261. Best guess is that the engine is a '60-'63 HD truck 261.
Here's the '60 VIK from the GM Heritage Center. Look to page #7 (8th page of the .pdf) for the service code shown in the attached image: 1960-Chevrolet-Truck.pdf
Confirming that ID, and narrowing the model year can be done with what Tim posted: casting numbers and dates.
Doug
1947 2nd-Series GMC FC152 3/4-ton
Follow the story in the DITY
1953 Chevy Bel Air Sport Coupe Powerglide
53&Me #1402565 03/22/2021 10:39 PM
If it is a 54-63 CHevrolet truck engine, here are locations of various "ID" codes.
53&Me #1402582 03/23/2021 12:44 AM
Thank you Tim and Doug, much appreciated. I'll start scrapping the crud off in a couple places. 😉👍
53&Me #1402622 03/23/2021 1:39 PM
ok, odly enough my head and block numbers are the same: head# 3836850 block#3769717
53&Me #1402625 03/23/2021 1:45 PM
I will be excavating the other numbers soon.
53&Me #1402636 03/23/2021 3:25 PM
'53, The block casting number confirms it's a 261. That casting was first used in '58, and continued throughout the following production years, into early '63. That head is also the factory casting used on 261s.
From Tim's info, you'll see that the block date code is cast just behind, and slightly above the starter. You should see a letter-number sequence that will start with something like CON4 - ignore that, it's just the conveyor used in the manufacturing plant - followed by a letter-number sequence that decodes to the casting date. To see the date code on the head casting, the valve cover needs to come off. It will be driver's side, just a little aft of the carb.
In any event, great engine. If you are rebuilding, check thoroughly/magnaflux for cracks in both head and block castings. Trucks used hard were somewhat prone to developing thermal-stress cracks.
Doug
53&Me #1402953 03/25/2021 1:05 PM
I removed the valve cover and found casting number B152, I'll try to get the block number in the next day or two.
53&Me #1402976 03/25/2021 4:43 PM
So from what I can tell, the head is dated: February 15 1962
53&Me #1403047 03/26/2021 12:31 AM
'53, that is correct on the head date. Let us know what you find for the block.
Doug
