0 members (), 105 guests, and 3 robots.
Topics128,194
Posts1,057,261
Members48,466
#1402427 03/21/2021 10:56 PM
Does anyone know where I can get a set of axle flange seals for a 42 1.5 Ron with a 2 speed axle. Were these originally metal? Thanks
Bah
Crusing in the Passing Lane
Usually there is a number on the seal. Otherwise, need the axle Mfgr., etc to find it.
Helpful to state kind of truck, etc. so others can know where to start.
Ed
Sorry, it is a chevy 1.5 ton dump truck with duals and the two speed axle.
Bah
7
7 Offline
It might have been a metal "shim" style gasket but the modern ones I have seen have a rubber coating on them. When I needed them for my 2 ton LCF I just made them myself from FelPro paper gasket stock. They are not leaking.
Are you talking about the seal that mates between the axle shaft and hub? They were a tin/lead material called terneplate. Can you give the dimensions? They may be the same as found on deco military trucks.
Lots more pictures
Thanks, will have to check dimensions. Will probably remove axle tomorrow.
Bah
.Made the gaskets, no leaks. Thanks 78buckshot. Sometimes you try and over think things.
Bah
I make those axle flange gaskets from very soft aluminum sheet metal about .030" thick, using the dimensions of the hub and the bolt hole diameter and spacing as a pattern. They seem to work better and last longer than gasket paper, especially if the flange doesn't have tapered collets that keep the axle from shifting slightly forward and back on the studs.
