| | | Forums66 Topics128,065 Posts1,055,868 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2006 Posts: 240 'Bolter | | 'Bolter Joined: Jul 2006 Posts: 240 | 1965 GMC 1/2ton project for the last 10 yrs, tore down to the concrete floor and built back up replacing every wear item basically every thing new, front disc brake conversion, 350 V-8, T5 trans, SWB with a custom flat bed. Replaced the fuel tank with the Blazer 20 gal tank kit from LMC. I didn't not read the kit fully, it came with a 30ohm sender. New dash insert with new SW gauges Electric speedo, tach,oil pressure, temp,volt and fuel gauge 90ohm. There lays the problem, tried to locate a 90ohm sender, no luck at LMC or Classic Parts which are both local within 35 miles of my place. The mounting hole on the tank is to small to accept any sender I have tried, so finally got my head out of my backside and went to Auto Zone and found a Auto Meter 30ohm gauge part # 1425 that matches my gauges, $51.00 the same gauge from SW was $135. this is going to be driven not shown so that will work. Just venting thanks for listening.
You Learn more Listening than Talking
| | | | | Joined: Jul 2006 Posts: 240 'Bolter | | 'Bolter Joined: Jul 2006 Posts: 240 | Update on the never ending problem, The 30ohm gauge is not currently available from the supplier, so the search continues went to O-Reillys and searched for a sender, found one for a early 1970 Blazer and it fits and works with my 90ohm gauge. Not on their computer, had to dig the book out, just installed it and works fine. Classic Parts listed it but not available, soooo the O-Reilly part # is FG118A, I know that I'am not the only one that has run into this type of problem, hope this will help someone else in the future. Makes you wonder how this virus situtation will effect the classic and restoration field in the future.
| | | | | Joined: May 2007 Posts: 1,718 Moderator: 60-66 Trucks; North Eastern Bolters | | Moderator: 60-66 Trucks; North Eastern Bolters Joined: May 2007 Posts: 1,718 | Thanks for update and part number | | |
