8 members (dt235sd, Lonnie, Wickedbass, Gabes-trucks, Ponchogl, Otto Skorzeny, 2 invisible), 193 guests, and 2 robots.
Topics128,081
Posts1,056,076
Members48,434
#1401864 03/18/2021 3:14 PM
My truck is a 1950 3800 series. I'm having difficulty getting loose the bolts for the lower door hinges, the ones that fasten the hinge to the pillar. I want to rebuild the hinges but those bolts won't turn in the least, rusted in place after all these decades. All the top ones turned and are good. I don't want to try too hard and break them off. What have others done to get these out, or is it just break them and do some sort of repair with hex nuts or something else on the back so new bolts can be threaded in there.
Tom
I had a little luck (on my 67 suburban) by getting in behind and soaking them with "break free" (soak both sides). Then try and get them to move a little bit, soak some more. Maybe a little heat and a few hammer taps. Yours have a 17 year head start on mine tho.
Another quality post.
Real Trucks Rattle
As Rusty said, soak both sides with Kroil, PB Blaster, WD40 or your preferred penetrating oil. Let set a day or two and do it again. Let set another day and spray both sides again then tap the heads a few medium strokes of the hammer. Then try to just tighten (not loosen) a bit. Then spray again and see if they will come out. Good luck.
The back side of those weld-in nuts aren't really accessible (unless the cowl is rusted away like mine were. eek But even if you can't get to the back side of the nuts, soak them well with your favorite penetrating oil. If you aren't worried about paint damage, you can try heating the bolts with an OA torch, which usually breaks them free. Then another dose of penetrating oil and they should come out.
Good Luck
I will try the penetrating oil as you all suggest, and a few hammer taps also. At this point I'm not worried about spilling on the paint, a repaint of the interior and new outer cowl panels are in the plans also. I wanted to get the hinges rebuilt before I start tearing apart the cowl and things so at least the doors are free of excessive wear. I might just cut a bit of the old panel out of the way to get better access to the threaded part of those bolts, then I could use the heat also.
Tom
Crusing in the Passing Lane
Heat will do the best job, however it is rough on the tin! Minn. winters are the blame.
Ed
Curmudgeon
Curmudgeon
Here in the South the area between the fender and the lower cowl rusts out. Moisture then gets to the lower hinge screws.
Attached is a picture of a 49 before and after repair. The 50 should have louvers on the inside kick panel.
If your penetrant has a plastic tube, you may be able to fog the area below.
Penetrating oil, heat and persuasive blows from a hammer on an impact screw driver.
Be careful not to hit the hinge too hard. The hinge pocket is not that strong.
You may mess up your door alignment.
Heat the bolt, not the surrounding metal, with a jeweler's torch until it starts to glow. Try to both loosen and tighten it.
If by some miracle that fails to work, drill the bolts down the middle with increasingly larger bits until just before you hit the threads. Then you can crack it out in pieces and run a tap through it.
And if THAT doesn't work, cut the whole door jamb out and replace it with a donor one from another cab that's not so rusty.
1951 Chevy Panel Truck
AD Addict & Tinkerer
If you do use heat, and you still can’t turn it, hit it penetrating oil. The heat will help draw the penetrant in.
Phil
Project Journals
Stovebolt Gallery Forum
Thanks everyone for your advice. I'm sure it's going to take both heat and the penetrating oil to do anything with these bolts. I kind of think drilling them out is probably in my future (hate to think of that). But I will work on them and see what happens.
Buoymaker, thanks for the pictures, I noticed the new driver side outer cowl panel you show has louvers in it. Are they making that now for the drivers side, hadn't seen those before.
Tom
Speaking of penetrating oil, if you run out of your favorite store bought juice, try half & half of acetone & ATF. Works like a champ for me.
Craig
Curmudgeon
Curmudgeon
Good eye Tom! That image was flipped digitally but I didn't catch it.
1950 and back would have had the vent door on the driver's side not louvers.
One other thing I've seen done out of desperation after the head was rounded-out.
Tack weld a length of steel to the screw head and use as a level.
I am drilling out a broken door hinge bolt, it sucks.
3800 guy If your a welder you could could weld-on a lever handle with 7018 put pretty good heat in it (shield around it with wet rag,let it get cold then turn it. Cut handle off with your grinder remove and replace the bolt.
3800 guy weld onto them.
