1 members (cmayna), 149 guests, and 0 robots.
Topics128,114
Posts1,056,287
Members48,439
I am having difficulties removing the original gas straps that are welded to the floor of my truck. It looks like there are spot welds but on the one strap i drilled them out but when I tried to remove it seemed to be lifting the floor with it. Am I missing something in the removal procedure?
You probably missed one (or part of one) of the spot welds. They're in kind of a random pattern. I'm assuming that you already got the spot welds to the seat riser (a couple on each side of each strap bracket.
Thanks Kevin
I don't think I found the spot welds to the seat riser so as soon as I get a chance I will look. I will also look to see if aI missed one on the strap itself
