3 members (DadsFirstPickup, Hotrod Lincoln, Gib70), 103 guests, and 3 robots.
Topics128,089
Posts1,056,366
Members48,442
I just put the driver's door on my truck. The outside door handle seems to bind up when I go to open it and it does not spring back up on its own. It does stay up if you move it back. The door opens fine, but the weatherstrip makes closing it VERY hard. I hate to peel it back off, so I will see if it softens over time. What did I possibly do wrong with the door handle though?? Uninstalled it seemed like it worked OK.
It might be slightly out of alignment. Loosen the latch screws and handle screws. Retighten.
