2 members (MickeyP, Charles in CA), 38 guests, and 9 robots.
Topics128,012
Posts1,055,311
Members48,419
#1400994 03/11/2021 6:27 PM
Do any of you have a drawing with measurements for the headliner of a 1950 Chevy truck? I would like to make my own. My email address is [email protected].
1950 4400
When I made my own ABS headliner for my Suburban, I used construction paper to make a pattern. Then transferred it to the ABS. Paper and masking tape could be your friend.
Joe Alan You could buy a cheaper damaged one from carter, then use it later,or if just half of your old one is there copy it. Hard to make the pattern . Make my own out of cardboard then adjust it on the next one !!
Thanks for the help, sometimes I think I couldn’t make without the help on this forum.
1950 4400
I’ll give Jim Carter a call and see what he’s got.
1950 4400
Moderator, Electrical Bay
J Online: Content
I have an original one removed from a 1951, but there are 2 problems: it doesn't lie flat after all those years and two...it has shrunk over time. So you'd have to make yours larger and then trim it to fit.
~ Jon
